weak links
Old Dec 1, 2008 | 10:34 AM
big_ford_rednek's Avatar
big_ford_rednek
weak links
i have a 95 150 with a 4.9 5sp and 4x4. 127,xxx miles. i put a 4" body lift and 35"s on it. trying to figure out the weak links in the drivetrain and suspension and such for mudding and general off roading. im puting a skid plate to protect my tie rods due to the fact that i have bent 2 of them from running into rocks or stumps. also have a brush guard and heavy duty bumpers to protect the exterior. have decent u joints and a heavier duty clutch also when i installed the clutch i replaced the slave too. what should i be worried about breaking on the trail? anything different than most trucks? is this combo prone to any problems on the trail?
thanks in advance for any input.
derrek
Old Dec 1, 2008 | 10:46 AM
Opossum's Avatar
Opossum
I am not a fan of the 8.8 rearend. In perticular the fact that they are a C-clip design and can just fall apart leaving you in a ditch as your tire and axle roll by. Invest in a 9" or upgrade to full floater stuff.
