Has anybody converted an F-series 5 spd manual to auto (E4OD for example)?
My 91' F350 has a 460 with the HD 5spd manual. I would like to hear from anyone who has done a conversion. I am forced (by a left foot medical problem) to consider getting a different truck w/auto trans. But I thought I would ask if such a conversion would be feasible on my old truck instead.
just from what i know about doing swaps the other way lol is you will need a tranny cooler, to make up tranny cooler lines just use -an hose or hydrolic hose, you'll need a different flywheel/flexplate forget what the automatic one is called, maybe a different driveshaft and you'll have to do some fab. work on your crossmember. going from a manual to auto is easier than the other way around. and a c6 can handle some power too just use an "R" code servo valve and a good valvebody and converter any it'll handle around 450-500hp all day no problem.
