1964 fuse panel layout
Old Nov 30, 2008 | 09:02 PM
Customcab's Avatar
Customcab
Does anyone have a pic of the fuse panel layout of a 64 model F100?
Mitch
Old Dec 1, 2008 | 01:00 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1964 F100/750 Fuse Panel
Originally Posted by Customcab
Does anyone have a pic of the fuse panel layout of a 64 model F100? Mitch
The fuse panel, which Ford calls a junction block, plugs into the headlamp switch.
C4TZ11A647A .. Junction Block
Green Sales in Cincinnati OH has five = 800-543-4959
JST Automotive in Lebanon TN has one = 615-443-3086
Wesley Obsolete in Liberty KY has four = 606-787-5293
There's a very clear pic of it in the parts catalog (section 110, page 17) which shows the whole thing including the 4 fuses, connectors for the wiring, etc., but I can't scan and post it.
You might give Green Sales a call, and ask them to fax or email you the illustration.
Old Dec 1, 2008 | 11:16 AM
Customcab's Avatar
Customcab
Thanks Bill;
The 64 model I have has a new panel on the firewall ( PO); and the original panel is hanging below dash semi near the headlight housing.
Got a brake light failure to come on problem so having a daigram of the old panel will help me trace this issue.
Mitch
Old Dec 1, 2008 | 01:50 PM
gritsngumbo's Avatar
gritsngumbo
CC: I have a photo of a fuse box/headlight switch diagram for a 64, but darned if I can locate it in my computer. I'll keep looking.
Old Dec 1, 2008 | 04:20 PM
camperspecial65's Avatar
camperspecial65
can you post a pic of your new fuse panel ...in 65 they changed the fuse block design entirely as it was taken off of the light switch and mounted on the inside firewall below where the E brake mounts to the firewall.
I looked at the parts books and so on last night for some time...I found the pic Bill is referring to but damned if I could read which fuse was 4 which circuit...there are a total of 5 glass fuses...1 15 amp which in original setup configuration is parallel to the block and is nearest the light switch.
Theres 1 lil short fuse...its a 1 amp fuse mounted vertical below the 15 amp mentioned above..my guess is its for the instrument cluster lights or possibly for the radio if installed originally.
At the far end from the switch there are 3 fuses one on top of the other in layout...the bottom 2 are 14 amp fuses. By bottom I mean on the opposite side of the fuse block as the 15 amp fuse closest to the light switch/dash panel as installed.
The last fuse above these 2 14 amp fuses is a lone 7.5 amp fuse of the same length as the lower 2.
I hope this helps clear things up a bit...
- cs65
Old Dec 1, 2008 | 06:46 PM
gritsngumbo
Here it is. Finally found it.
Click on thumbnail to enlarge.
Old Dec 2, 2008 | 11:23 AM
airharley's Avatar
airharley
Home Page - The Old Car Manual Project has the entire wiring schematic as well.
Old Dec 2, 2008 | 01:52 PM
camperspecial65
great pic grits...did you get the from the shop manual ??? I love a clear pic that shows which fuses runs what
- cs65
Old Dec 2, 2008 | 02:53 PM
gritsngumbo
Hope it helps CC: I believe I got it from one of the guys over on the Slick 60's site. Probably Uncle Skip. I found it very helpful and have put a copy in my glove box for reference.
Old Dec 2, 2008 | 10:07 PM
Customcab's Avatar
Customcab
Thanks guys;
Man without you folks, us Shade tree's would be dried up.
The PO use a basic style fuse panel; (basically a jumper??) looks nothing like our 65 & 66 panels. Also, I'm ****-poor when it comes to posting pic's. sorry CamperSpecial65.
Everything in my Gallery is with the help of my local buddy & FTE'r "DAJUDGE 51". The sad thing is he's more computer genius and 70 than me at 46.. lol
Mitch
Old Dec 2, 2008 | 10:43 PM
camperspecial65
no problem CC...its all about helping our extended family of sorts on here keep their rigs running
- cs65
59CRL
Jan 1, 2014 07:05 PM
wrd0225
May 23, 2012 04:57 AM
powerstroker100
May 31, 2010 07:53 AM
SpykDaddie
2004 - 2008 F150
Feb 6, 2006 11:29 PM
bqueton
Jun 15, 2004 11:27 PM
