Sponsored by: Real Truck
2005 SD ball joint replacement questions
Old Nov 30, 2008 | 06:48 PM
vento's Avatar
vento
My driver's side ball joints are wasted. I've pulled it apart at work the other day to change them. I got as far as getting the wheel bearing off. Next step is to pull the axle, but then there is that seal in the knuckle. My truck has manual locking hubs, so i don't have to worry about vacum leaks. So my question is can the axle be removed without damaging that seal, and is it a pain to get it back in without spending the $75.00 on the seal driver from matco tools?
