F-250 Performance upgrades????
Old Nov 30, 2008 | 05:35 PM
afd0089's Avatar
afd0089
Hey guys I need some help on some mods for my F-250 Super Duty. Iam trying to post this in a few differnent spots to get as much feed back as I can. I have a 2008 F-250 FX4 with the 5.4. It has the automatic torque shift trans. and 4.10 rear end. I am thinking of doing a cat back exhaust system (supper 44), K&N Gen. II cold air intake, and hypertech computer programer. My questions were 1) Are these mods worth it? 2) Does the flowmaster sound good on the 5.4's? 3) I am going single in dual out, does it make a difference in performance wheater I dump them both out behind or in front of the Passenger side rear wheel. 4) What kind of horsepower/torque gains should I see? 4) Will any of this void factory warranty? Any and all input would be great....thanks guys.
Old Nov 30, 2008 | 10:08 PM
303soul's Avatar
303soul
I don't know what the actual setup is on 2008s is as far as intake and exhaust goes, but my 2003 F-350 with the 2v 5.4 had noticeable gains with a tuner running high octane gas, and this was coupled with a high flow single exit exhaust and a K&N replacement filter (not the cold air kit, which in my opinion shouldn't be called "cold air", because of the inlet location, but that's me...). After the gas prices rose I set it back to regular, because the gains aren't worth paying that much extra money. So if you want something that will blow your socks off you should try getting a supercharger, nitrous or maybe contemplate trading your truck in for a v10 or the diesel.
Old Dec 1, 2008 | 05:46 AM
hvac guru's Avatar
hvac guru
use a sct x-cal 3 with custom tunes from mike troyer ,www.troyerperformance.com air force one intake,magnaflow siso catback.
Old Dec 1, 2008 | 10:00 AM
Bear River's Avatar
Bear River
Former ******
The best gains can be realized by addressing the most restrictive parts of the system, namely, the y-pipe and the factory muffler. I don't think it matters much from a performance perspective where you bring that tailpipe out.
A catback should not adversely affect your warranty. I wouldn't expect to see a huge gain, but it would be noticeable especially in combination with your other mods.
Old Dec 1, 2008 | 01:44 PM
dkf's Avatar
dkf
Overall the intake and exhaust setup on the 08' SDs is not that bad. A free flowing muffler and a nice tip is about all I'd do to the exhaust end. A catback is fine if you want to spend the $$$. The y-pipe area is fine on these trucks. The intake has a bunch of sound deadening chambers that no doubt hurt performance. I would look at and SCT Xcal like hvac guru suggested, even running 87 there are gains to be had. IMO SCT is the best tuner on the market for Ford trucks, gassers anyway.
Old Dec 1, 2008 | 05:10 PM
hvac guru's Avatar
hvac guru
obviously you never saw a oem y pipe cut open have you? my drivers side went 3/4 " into the left side down tube where it merges-absolutely zero quality control there!
Old Dec 1, 2008 | 05:41 PM
hvac guru's Avatar
hvac guru
also 90% of the pcm codes in superduties are very slow to got into closed loop-most never do except at wot,superduties gain much part throttle tq a quality custom tune
Old Dec 2, 2008 | 02:35 AM
Bear River's Avatar
Bear River
Former ******
O would think you could gain a good amount of power with a tune, but you would also probably have to run a higher octane fuel to get the most out of it.
The factory y-pipes are aweful. The merging is not reallt the problem either, its where they merged it. There is no practical benefit to merging the pipe going into the y. Ford does it to make manufacturing cheaper. I'm not sure what the '08 system looks like, but the previous years were awful. But the biggest choke point is the muffler, and replacing it is where you will see your biggest gain.
Old Dec 2, 2008 | 09:55 AM
dkf's Avatar
dkf
Not the inside of an 08'. Have any pics? You think your 08' y-pipe is bad you should have saw the y-pipe on my 04'. The 08' is much improved over the 00'-04' y-pipes. Always room for improvement though, no matter what vehicle. How much improvement though varies.
You have your loops mixed up though. The stock tuning doesn't allow open loop at WOT. The truck runs in open loop for a little after startup then goes into closed loop and stays there.(Will switch to open loop during hard engine braking when the injectors are shut of) With a good tune at WOT the truck goes into open loop.
Old Dec 3, 2008 | 11:22 AM
hvac guru's Avatar
hvac guru
not-my 04 fdy2 never wanted to go into closed loop fyi
Old Dec 9, 2008 | 07:42 PM
afd0089's Avatar
afd0089
Thanks for the help guys. One more question for you....The exhaust, I am going to put either a flowmaster 44 or a gibbson. Which one do you guys prefer and what would you run for pipe size? Factory is 3" which will stay the same, but the dual outlets on the muffler...should I go 2.5" or 3.0". I will be dumbing them both out before the rear passenger side wheel. I keep hearing the 3.0" is to much and will hurt my performance...is this true should I go with the 2.5"????? Thanks
