pulled my 6speed out today
Old 11-30-2008, 05:18 PM
chrisjrosenbohm's Avatar
chrisjrosenbohm
chrisjrosenbohm is offline
heres what i have 200 f350 4x4 6speed build date 3 2000. 4 inch exhaust predator programer hutch mod shimmed fpr. cluth was making some bad noised. pulled apart pilot bearing was completely gone. to my suprise it has the dual mass flywheel wich is dead i pulle a whole sandwich baggie full of parts out of the bellhousing. all the springs are out of the flywheel and broke into little pieces it chipped the end of the starter dented the oil pan up a bit but no realy major damage. gonna go with a solid flywheel and suggestions. it has 281k miles and i have no idea on the maintence history. carolina clutch has the luk kit for 600 do i nneed new new flywheel bolts? or pressure plate bolts?
thanks
chris
Old 11-30-2008, 07:11 PM
Hiflyer746's Avatar
Hiflyer746
Hiflyer746 is offline
If I remember correctly. . . the new kit should have new bolts in it. When I got my cerametalic clutch. . . I believe it had new bolts. But if not. . . you got it apart. . . I'd get a new set and put them in there with a nice torque wrench
Timmy
