8.8 compatibility question
Old Nov 30, 2008 | 08:20 AM
Talyn's Avatar
Talyn
Is there any major differences over the years that would make a newer differential not fit in an older rear end?
I have an 87 axle, but need a new carrier, and the carrier i found is a 2000ish.
Old Nov 30, 2008 | 08:23 AM
Talyn's Avatar
Talyn
Spline count: 28
Casting#: F5AW-BB
Other casting markings: 6F05 (Maybe the date?) & WF9
This is the info i have on the newer carrier.
I have a 95, but my axle is from an 87.
The tag said LS on it, but it is an open rear end.
I'm tired of it and a member has this new carrier to use.
Old Nov 30, 2008 | 12:52 PM
85e150's Avatar
85e150
Any info on a tag? Look for "WEG" or similar. "WF9" does not appear in the decoder ring I'm looking at.
Old Dec 1, 2008 | 01:05 AM
aurgathor's Avatar
aurgathor
For one thing, the bolt pattern is different. There should be plenty 8.8" of the correct vintage. (until '96)
Old Dec 1, 2008 | 04:18 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The 8.8 is an integral rear axle, which does not use a carrier. A 9" has a carrier, not an 8.8.
What part do you actually need?
If you need the case that the ring gear bolts to, the same one (E7TZ4204E) was used from 1987 thru at least 2001, but after 1996, the axles will be different, because Ford went to metric wheels in 1997.
Old Dec 1, 2008 | 05:04 AM
phil6608's Avatar
phil6608
Spline count: 28
Casting#: F5AW-BB
If the tag said LS,,I would say there's a good chance you just need a rebuild kit for the LS diff.
Old Dec 1, 2008 | 10:13 AM
Talyn's Avatar
Talyn
I know the difference between an 8.8 LS and an 8.8 Open.
There is no place for clutches on my rear end, its just all free moving.
I had the clutches and everything ready to go, and ... I was confused.
Thanks for the answer Numbers Dummy, I shoulda just Pm'ed you in the first place, cause you know this stuff.
That is the answer I wanted to know. =)
jberylecrider
20
Oct 25, 2024 05:57 PM
carlspeed
Jan 4, 2017 07:55 PM
FordPurpleRanger
May 19, 2015 07:32 PM
powerstroker100
Nov 1, 2011 08:04 PM
skyjacker10
Dec 16, 2009 09:58 PM
