Modular V10 (6.8l)
2000 V-10 missing
Old Nov 29, 2008 | 02:02 PM
Broken Wallet's Avatar
Broken Wallet
Cool 2000 V-10 missing
Hey people, I have a 2000 Excursion with a V-10. It has 90,000 miles that I just cannot find what's causing what seems like a low speed mis. I have replaced the fuel pump (Had no fuel pressure), sparkplugs (used Autolite plugs), all new coils and boots. There is no check engine light and no codes set. I don't know what else to do any ideas?
Old Nov 29, 2008 | 02:22 PM
Fordfanatic4life's Avatar
Fordfanatic4life
u sure its a miss ??
maybe its a slight exhaust leak ???
buying all new coils must have been expensive..
Old Nov 29, 2008 | 02:42 PM
Broken Wallet
Yea I'm sure you can feel it and I am sure the truck has no exhaust leaks. also it's not consistant.
Old Nov 30, 2008 | 11:13 AM
Big Orn's Avatar
Big Orn
Do you have an EGR? Sometimes it will cause the engine to run rough when it fails.
Around here it only costs about $50 to have the Ford dealership to run a diagnostic on the engine. It's worth it, imho.
Old Nov 30, 2008 | 11:59 AM
Skoda's Avatar
Skoda
does it also "miss" when sitting in your drive way idelling?
Old Dec 1, 2008 | 06:32 AM
Broken Wallet
yes it will miss at idle.
Old Dec 1, 2008 | 12:37 PM
Big Orn's Avatar
Big Orn
Broken,
Check that little rubber elbow that attaches to the front of the throttle body and runs to the PCV valve on the driver's side. You can't tell by looking sometimes, so you'll have to remove it. Look for deteriorated portions of it.
Old Dec 1, 2008 | 11:47 PM
Skullonarm's Avatar
Skullonarm
Vacuum line rotted out? Spray some carb cleaner around the lines and see if the rpm increases. If it does you have aleak. Try to pinpoint it wth the same method.
Old Dec 2, 2008 | 07:45 AM
Broken Wallet
Thanks guys I am going to try those ideas as soon as I get home to the US this weekend
V10Train
Modular V10 (6.8l)
May 27, 2012 10:50 PM
RAR56430
1997 - 2003 F150
Apr 7, 2009 07:48 PM
greggraymo
Jan 11, 2008 08:21 PM
LeafAngel
Mar 20, 2005 09:02 AM
roadkill
Mar 8, 2000 09:35 PM
