2000 X fuel filter?
Old Jan 17, 2005 | 06:22 AM
LeafAngel's Avatar
LeafAngel
2000 X fuel filter?
Howdy all!!
I have a 2000 X w/ the V10 and need to know where the fuel filter is located.
Thanks!!
Leaf
Old Jan 17, 2005 | 10:40 AM
fomoco_1's Avatar
fomoco_1
Have you tried the right (pass.side) inner frame rail?
Old Jan 17, 2005 | 11:31 AM
Trustee's Avatar
Trustee
You need a special tool to pop off the fuel lines. The can then pops right out of the spring bracket. A breeze compared to my old Suburban where the thing was bolted on and you had to spill fuel up your sleaves.
Old Jan 17, 2005 | 05:55 PM
Caniac10's Avatar
Caniac10
On my 2000, it is on the frame rail under, the drivers seat. I did not need the tool...just some good plier creativety.
Old Jan 17, 2005 | 06:15 PM
Hoowasat's Avatar
Hoowasat
Get the special repease tool. It's relatively inexpensive, and a lot less aggravting than the pliers-method. Besides, it's too easy to screw up the internal O-rings using anything but the release tool. It is indeed located on the inside of the driver-side framerail, below the driver's footwell.
Old Mar 18, 2005 | 05:37 PM
needgas's Avatar
needgas
Its on the left side(drivers) under your feet on the inside of the frame rail
Old Mar 20, 2005 | 09:02 AM
slc10844's Avatar
slc10844
Don't forget to bleed the schrader valve on the fuel injector rail before removing the fuel lines. If you don't you might get sprayed with gasoline.
DiesalBoyz2000
Dec 26, 2010 07:03 PM
97REDPSD
Nov 30, 2007 01:05 AM
tileman1
Jul 14, 2007 05:14 PM
czabala
Oct 11, 2004 11:34 AM
2kf150
1997 - 2003 F150
Jul 9, 2003 11:58 PM
