Altenator Problem
Old Nov 29, 2008 | 12:44 PM
Bender99's Avatar
Bender99
Altenator Problem
For some reason my altenator doesnt work. I put two different remand ones in and it dont charge the battery. connections all seem good. I dont know where to go from there. I didnt drive it for a while then all of a sudden its not working. What things should I be checking out? Its a 91 f150 302
Old Nov 29, 2008 | 03:58 PM
John SCB's Avatar
John SCB
Did you bench test the old alternator (and new ones too)? How about testing the battery? You should test both of those critical components then go from there. FYI, if the battery is not fully charged your alternator will fail quickly. They don't really recharge the battery the same way they did in the olden days.
Old Nov 29, 2008 | 04:25 PM
danr1's Avatar
danr1
What he said^^^^ and check the fuseable links at the fender mounted starter relay, inspect and test them for continuity .
Old Nov 30, 2008 | 12:05 AM
Bender99's Avatar
Bender99
yeah i had the old one tested, the machine wouldnt even run it and then they grabbed a new and ran fine but i went back the next day to buy it. that didnt work so I took it back and got another one. Battery is fine im pretty sure cause I use it in my mustang with no problems. Ill test the wires, see what comes up with that
