Axel decode help
Old Nov 29, 2008 | 01:37 AM
cqyqte's Avatar
cqyqte
Axel decode help
Good evening - I have a 1976 F250 Crew Cab I broke a rear pinion and ring gear. The BOM on the rear is 603717-11 from the axel tag between bolts. This drives like a locker rear end. The front BOM is 603765-2. I do little towing and use it for mountain hunting. Since I have to replace both ring and pinion gear, I want to swap gears from 4.10 and to 3.73. Am I crazy is it a simple pinion and gear swap or do I need a carrier. I am hoping for better milage. Yes I know the 4 barrel and the 460 swap is not helping but I would prefer higher top end when travleing around a fairly large state. I have done about everything I can do on these age class of pickups (engines, tanny and tranfer cases ect.) except the repair I need to do now (ring gear and pinion). After reading the steps and techs I am getting more nervous about getting it done shimmed, backlash and free play done correctly.
Thanks for the help...
