Sponsored by: Kumho
brake/rotor replacement question
Old Mar 5, 2002 | 07:45 PM
docleonard's Avatar
docleonard
Old Mar 18, 2002 | 11:28 AM
vtsocalm's Avatar
vtsocalm
Hello,
I went to the shop to have my front brake pads replaced and was told that the rotors had to be replaced as well. Is this possible? I have a 1999 F-150 with only 37,000 miles. I was told that the new brake pads have metal in them and wear the rotors very much more quickly than pads from years ago.
Could this be correct?
Any help please,
Greg
Old Mar 18, 2002 | 09:25 PM
RE_SPEED_FAB's Avatar
RE_SPEED_FAB
Doesnt sound right to me, maybe get a second opinion.
Old Mar 19, 2002 | 02:05 PM
greenpus's Avatar
greenpus
Go somewhere else.
Old Mar 20, 2002 | 07:35 AM
rabidranger's Avatar
rabidranger
[updated:LAST EDITED ON 20-Mar-02 AT 08:36 AM (EST)]Unless the rotor is really grooved bad than you shouldn't need new ones. Or if the rotor is warped bad they may recommend a replacement. Was there a pulsating when you braked? (not the ABS kind of pulse though) At the worst they should be able to grind the surfaces flat for you. If none of the above is true, go somewhere else and boycott the place.
Old Apr 6, 2002 | 08:16 AM
Maxthemutt's Avatar
Maxthemutt
[updated:LAST EDITED ON 06-Apr-02 AT 09:16 AM (EST)]Unless It was metal on metal for sometime, or you had them machined previously, I'd say it's unlikely their under spec. However, the rotors really rust onto the hubs in the 97 and up trucks. They may be saying they can't save the rotors because they'll be destroyed on removal. Good luck Max
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
