Oil Confusion
Old Nov 28, 2008 | 11:41 PM
5hole's Avatar
5hole
Oil Confusion
I'm confused folks. Getting ready to change the oil in my 2000 here in Northern Kentucky. I'm just south of the river and Cincinnati Ohio. If I look at the manual, I'm confused as to whether 10w-30 or 5w-30 would be the best choice. If I look at the 10w-30 range, does the black bar that says Preferred count? Or is the temperature range in the white bar to the right what it is saying is preferred? We will certainly have days over 30 before my next change. But something is telling me to use the 5w-30. If it matters, my last change was Rotella T 15w-40. Thanks folks!
Old Nov 28, 2008 | 11:53 PM
dvfd12's Avatar
dvfd12
I would use Rotella syn 5w40 or Schaeffers 5w40. If thats too expensive then just stay with the Rotella 15w40.
Sounds like you are looking at the gasser part of the manual.
Old Nov 28, 2008 | 11:54 PM
95Z71's Avatar
95Z71
Yes, Rotella 5w-40 Synthetic is great oil to you especially if it gets really cold where you are. I along with others run it year around. Downside is that it's 22.00 per gallon.
Old Nov 28, 2008 | 11:56 PM
jtharvey's Avatar
jtharvey
For a diesel, you don't want either of those oils. You'll have a difficult time finding either of those weights in a diesel approved oil. Making sure the oil is diesel approved is of the utmost importance for a diesel engine. Diesels put a lot of soot and more dirt into the oil, and a diesel rated oil has extra detergents to counter act the extra dirt.
You'll want to find either a 5W-40 or 15W-40, depending on how cold it's going to get. Up there in Ohio, I would get the 5W-40 synthetic. Good brands are Schaeffers, Delo 400, and Rotella.
The 10-30 and 5-30 ratings are for the gas engines. Your truck should have a supplemental manual that is specific to the 7.3 Diesel.
Old Nov 29, 2008 | 12:45 AM
4inchlovin's Avatar
4inchlovin
LOL Thanks JT i was going to point that out!
Old Nov 29, 2008 | 08:25 AM
5hole's Avatar
5hole
Ugh, my bad. I knew something didn't seem right.
Over the next three months or so which is about how long it'll be before my next change, average temps are between 20 and 45. We'll have some teens and zeros in there though for sure. I planned on switching to syn in the spring. Maybe I should just go ahead and do it now.
Thanks again for the pointers!
Old Nov 29, 2008 | 08:51 AM
stevestroke01's Avatar
stevestroke01
Actually Rotella and Motorcraft make a 10w30 diesel oil. The 10w30 will work fine for you in the winter months as long as you are not towing to much. If towing I would run the 5w40 or stick with the 15w40. I live in Southern Indiana and I ran Motorcraft 10w30 in my 6.0 in the winter and you could tell a big difference in cold starts with the HEUI system on the truck. I just picked up some more Motorcraft 10w30 oil last week that I'm going to put in my 6.4 for the winter months. I do agree the 5w40 oil would be best in your truck in the cold months its just to much money for me and I'm not going to run extended drain intervals anyway.
Old Nov 29, 2008 | 09:04 AM
sneak's Avatar
sneak
I was JUST about to mention that, thanks.
Old Nov 29, 2008 | 09:14 AM
5hole's Avatar
5hole
I don't plan on running extended intervals either, I'll change again in 5k. And I will not be towing anything.
I double checked what I looked at last night:
http://www.motorcraftservice.com/pub.../00700732e.pdf
Looks like the diesel supplement to me. I pulled it off Ford's Owner site. I need to get out of the house and check the manual in the truck I guess.
Thanks again for the info guys.
Old Nov 29, 2008 | 09:47 AM
bkcowboss's Avatar
bkcowboss
5W 40 is really the best year around, it has the same high temp viscosity as the 15W 40 with better cold weather viscosity properties because of the synthetic molecular stability.
Old Nov 29, 2008 | 11:39 AM
clintbonnie's Avatar
clintbonnie
The important thing to check on whatever oil you use, is to check the bottle for the "Meets API Service", .. It should be CJ-4 along with a SL or SM ..
I also vote for Rotella T 5w-40 year round.. my engine loves it..
Old Nov 29, 2008 | 01:45 PM
jdecker88's Avatar
jdecker88
Actually Schaeffers is cheaper then Rotella Syn. if you get it from a Rep. in a 300 dollar bulk order instead of buying it in stores at markup pricing.
Old Nov 29, 2008 | 08:21 PM
jtharvey's Avatar
jtharvey
Just a little clarification...the "minimum" order is now up to $350. As shipping companies start to charge more, the dollar amount of the order had to go up as well. Now, it's not actually a "miminum" order just to place an order, but if you place an order for $350 or more, pre tax, the shipping is free. However, if you find the right rep, they'll give you the wholesale pricing at less than the "minimum" order, but you will have to pay actual UPS shipping charges.
I always figured I'd rather order a little more oil now and spend the extra on actual product rather than shipping charges. Usually, I'd place one order for all my oil, grease, and fuel treatments to use in the truck and jeep, which would have me set for the whole year. It's sometimes tough to spend that much all at once on oil, but it was much easier knowing I'd only have to do it once a year, and always had the oil on hand when I was ready to change it.
Old Nov 29, 2008 | 08:40 PM
jdecker88's Avatar
jdecker88
I was close heh, it is worth it to just get the full order or just share the order with a PSD buddy thats near by (thats what I did) and if you cannot find a rep to work with you in your area there is reps on here that can work with you .
Old Nov 29, 2008 | 08:45 PM
rbaker6336's Avatar
rbaker6336
is the price of Schaeffers what ever market will bear? their site don't have a price list like amsoil does
I see a bulk plant near me sells Schaeffers
