Modular V10 (6.8l)
Running rough when cold
Old Nov 28, 2008 | 08:18 PM
95 Lowbuck's Avatar
95 Lowbuck
Trailering
I've got a 2000 Excursion with the V-10
It has developed a miss and runs rough when cold.
After about 10-20 minutes it seems to clear up and run fine.
Changed fuel filter, cleaned TB, new plugs, new air filter
and checked vacume lines but no luck.
Any ideas?
Old Nov 28, 2008 | 10:18 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Change coil boots
Denny
Old Nov 29, 2008 | 07:03 AM
95 Lowbuck's Avatar
95 Lowbuck
Trailering
Sounds logical, but why would it clear up when warm ?
Old Nov 29, 2008 | 10:10 AM
rvpuller's Avatar
rvpuller
You have moisture trapped in the plug holes and the boots are leaking to ground when cold but it will dry out after warm up. I have the same problem but haven't replaced the boot yet.
Denny
Old Nov 29, 2008 | 03:25 PM
95 Lowbuck's Avatar
95 Lowbuck
Trailering
It was the Coil Boots.
They were not cracked but stretched big leaving
clearence between it and the plug.
Thanks for the help!!
