Intake Gasket
Old Nov 28, 2008 | 06:59 PM
straightsixer's Avatar
straightsixer
Intake Gasket
What is the common belief here on the use of RTV on the gasket between the lower manifold and the heads? I've purchased the stiff reinforced cardboard type gasket and wonder if I should use a sealant? And what about the gasket between the upper and lower manifold?
Old Nov 28, 2008 | 09:11 PM
Conanski's Avatar
Conanski
I always use the lower intake gaskets and never have a problem, I glue them to the block with contact cement and fill the gaps at the ends with RTV, never a leak. You definitely need a gasket between the upper and lower intake.
Old Nov 29, 2008 | 08:16 AM
EPNCSU2006's Avatar
EPNCSU2006
I put RTV around only the water ports in the intake manifold gaskets and the corners at each end as Paul mentioned. I install the upper to lower manifold gasket dry or maybe just a little high tack to hold it in place.
warren561
Aug 19, 2013 11:36 AM
oldblue89
Jun 27, 2010 11:38 AM
jadmt
Dec 18, 2008 11:00 PM
Steve Tyree
Sep 16, 1999 04:18 PM
