94' 460 ECM location
Old Nov 28, 2008 | 05:34 PM
ropnjessi's Avatar
ropnjessi
I'm not to familiar with the Fords, but I have a problem with this one. When normal driving on the highway the truck will either miss/cutout every now and then. Its not like a spark plug miss that is consistant. When under load it will happen a little more frequently. Dealership could not get to the bottom of this problem, all they ended up doing is change out a sensor. After asking around other people seem to lean towards the ECM, so as a last effort I was going to change the ECM out but am not sure where it is located on this 94 F-350 Dually gas/460 engine, any advice on this matter would be of great help....
thanks
Old Nov 28, 2008 | 05:53 PM
quicklook2's Avatar
quicklook2
in engine compartment look below brake booster a little to the outside.
disconnect battery before playing around with it.
Old Nov 28, 2008 | 06:25 PM
White 97 xlt's Avatar
White 97 xlt
How old are the plug wires?? They "could" be breaking down under load.. Just a thought.
Old Nov 28, 2008 | 06:31 PM
danr1's Avatar
danr1
<i>Dealership could not get to the bottom of this problem, all they ended up doing is change out a sensor.</i>
I'm not at all surprised, from what I've seen dealer's couldn't fix a bicycle with complete instructions to follow to do so. They play around with one for hours, sometimes days even, only to give it back in the end stating something like "we really couldn't find anything wrong with it" accompanied by a big bill. Having changed maybe the odd sensor or two "guessing" at it, heck all of us can do that.
How many miles on this truck? Do you live in the snow belt? IE does it have lots of rust and corrosion? Has the electrical harness been hacked into at any point?
I take it the cap/rotor/wires and plugs have all been replaced? Known "quality" stuff put on, no "auto supper mart" stuff?
How about the TFI module, the stator (PIP) in the distributor, or the distributor? Any of it been replaced with the cheap stuff from the before mentioned source?
How about the coil?
The distributor original with high mileage? have any play in its bushings?
I gotta go out on a limb right off the bat and say from what you posted so far I don't think its the computer.
Pull the spout and take it for a ride, do the same thing?
What sensor did they replace?
Old Nov 29, 2008 | 02:44 PM
ropnjessi's Avatar
ropnjessi
How about the coil?
Thanks for the comments, this gives me a starting point, as I am no mechanic there are 104,000 miles on the truck. The truck was in Oregon for a time but for the last 4 years its been in the southern Nevada desert. I'm not sure what the IE and TFI module are. Sorry what do you mean by "pull the spout"? They replaced the oxygen sensor I think. This problem is really noticeable when pulling a load. Hey thanks for your help and suggestions....
Old Nov 29, 2008 | 02:59 PM
quicklook2's Avatar
quicklook2
why did you think it is the computer?
buy a manual so you can look up the parts referred to in other posts.
should be your first purchase before you go tearing into the vehicle.
Old Nov 29, 2008 | 04:01 PM
ropnjessi's Avatar
ropnjessi
As mentioned in post #1 the Dealership suggested it was the computer, as well as other researching with other sources. I am using this website as resource. I asked the question on a day I am not able to purchase a manual. Thanks for your help....
Old Nov 29, 2008 | 04:39 PM
quicklook2's Avatar
quicklook2
when they suggest it is the computer or from your research on it: what says computer is the problem?
usually it is not being able to read codes or fuel pump staying on.
what are the signs you get?
Old Nov 29, 2008 | 04:56 PM
ropnjessi's Avatar
ropnjessi
To be honest, its been so long since it was at the Dealership I don't recall why. Something I do know about is on my Dodge cummins when the ECM went out on it, I could still easily read codes and my lift pump was not affected. Its simply a circuit inside the ECM that got fried. I think dnar1's suggestions are good one's and I will start there. I tend to agree its not the ECM but its always good to get other people's experiences for information, so I have to ask.
HeatherRose
Jan 3, 2023 05:10 PM
BILLYBOB168
Sep 24, 2014 11:37 PM
ragsims1544
Jul 2, 2013 09:25 AM
rondawgg1118
Apr 24, 2009 07:49 PM
cfhurdle
Dec 4, 2004 09:02 AM
