Sponsored by: Kumho
Extended Brake Lines
Old Mar 17, 2002 | 11:35 AM
Big89's Avatar
Big89
Hi
I am going to lift my 85 F150 4x4 4" and am wondering if I will need longer brake lines.
Thanks
Old Mar 17, 2002 | 11:40 AM
orange peel's Avatar
orange peel
you really should get longer brake lines for any amount of lift you get. but you might not, one of my friends didnt put longer brake lines on for his 4" lift and hes fine.
Old Mar 17, 2002 | 09:04 PM
MustangGT221's Avatar
MustangGT221
You probably do, my 95 needed new ones, front and rear. I recommend skyjacker's stainless braided lines, they will improve your braking. I was very happy with them, i can stop better. Got them at 4wheelparts.com
Primary rig is:
95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds
Then theres:
88' F-250 Superduty 351 + c6
92' Thunderbird 3.8L V-6 FOR SALE!
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 and a
3 spd column shifter baby.
The newest addition to the Ford family is a 99' Mustang GT 4.6L
Old Mar 18, 2002 | 12:57 AM
aksniper's Avatar
aksniper
I don't know if you "NEED" the longer brake lines but I agree that you should go ahead and get the longer brake lines and would recommend the stainless steel braided ones. If not for the length...buy them for better braking. Goodluck.
James
Old Apr 6, 2002 | 08:21 AM
Maxthemutt's Avatar
Maxthemutt
You guys really feel a difference in braking with the stainless lines?
Just curious, I'm thinking about a lift as well, can you define whats better? Thanks, Max
Old Apr 7, 2002 | 12:51 AM
85351ho's Avatar
85351ho
i did, you get a much quicker response, and a stiffer less spongy pedal
Old Apr 8, 2002 | 09:48 AM
Ryan50hrl's Avatar
Ryan50hrl
I got a much better braking distance, i'd say that the lines decreaced my stopping distance from 60 mph by 20-30 feet. The pedal is much firmer and the truck stops great, another thing that radicaly helped my braking were cross drilled rotors from summit racing.
Ryan
Old Apr 8, 2002 | 10:04 AM
AZ4x4f150's Avatar
AZ4x4f150
go into the off-road forum and look for the posting named "lift kits on a TTB and brakelines" I have done this modification to alot of fords and other lifted trucks and jeeps for off-roading and for articulation reasons and you can achieve all the flex you want without tearing out a brakeline and you can do it yourself for alot cheaper than a complete set of extended brakelines.
Old Apr 8, 2002 | 01:40 PM
MustangGT221
reelickj
Sep 21, 2012 01:11 AM
halltm
May 31, 2011 11:33 PM
midcal48
Feb 12, 2011 07:41 AM
MikePacey
Feb 7, 2011 02:34 PM
tangcoral2004
Apr 26, 2005 01:45 AM
