two questions
Old Nov 27, 2008 | 04:46 PM
ssquints999's Avatar
ssquints999
two questions
new guy on the block i have a 92 f150 351 with a e40d.1)i can't get the 4x4 to engage. 2) i'm getting 5mpg right now i have replaced air filter, plugs, wires, and fuel filter why is my mileage so horrible
Old Nov 27, 2008 | 06:32 PM
quicklook2's Avatar
quicklook2
welcome to fte.
way more info on both issues.
mileage? just bought or has it just started acting up? codes? etc?
Old Nov 27, 2008 | 06:47 PM
guitarnik's Avatar
guitarnik
welcome to FTE. yes yes more info
Old Nov 27, 2008 | 06:55 PM
Powerstroker_18's Avatar
Powerstroker_18
I've had a few buddies that have 351W trucks in those years in 1/2 and 3/4 ton with automatics and the best they ever got was 5 or 6 too. Neither of them were hard drivers
Old Nov 27, 2008 | 07:01 PM
Old93junk's Avatar
Old93junk
Im getting 11.5 w/ 460, somethings not right. pull the codes. could be bad o2 or bad cat. vaccum line may be off 4wd acctuator, have alot to do w/ both problems.
Old Nov 27, 2008 | 07:05 PM
ssquints999
the truck was sitting for 2 years i got it and put injector cleaner in it it idles a little rough. the 4x4 i can hit the button either high or low and nothing happens at all. i've pulled codes and a code 62 comes up which is a clutch converter error and the book said for years 89-90 or 91 but mine is a 92 so i didn't think that pertains to my truck
Old Nov 27, 2008 | 07:10 PM
quicklook2's Avatar
quicklook2
what brand and kind of plugs? wires?
did you do cap/rotor?
an injector cleaner will not magically bring back to life a truck sitting for 2 years.
the injectors may be clogged.
Old Nov 27, 2008 | 07:11 PM
danr1's Avatar
danr1
Something was wrong with their trucks too!
Should get in the neighborhood of 12-15 with it depending on loaded or not and how fast its driven.
Old Nov 27, 2008 | 07:35 PM
Old93junk's Avatar
Old93junk
Sounds like there may have been a reason its been parked for 2 years. hope the gas isnt 2yrs. old. clear the code and start over. Sounds like major tune up time. start there and see what develops.............remember, go slow and have patience.
Old Nov 27, 2008 | 07:47 PM
ssquints999
plugs are motorcraft the wires are omni spark. did not do the cap.
it was parked for 2years because the po started driving a 1 ton for the trucking company my grandpa works for so he didn't have a need for it anymore i bought it from him for $200 with brand new tires and wheels on it and a tool box full of tools.
i drained the tanks and cleaned them before filling them up so the gas is fresh. i'm only running the rear tank caust eh front needs a sender and pump
Old Nov 27, 2008 | 08:09 PM
Old93junk's Avatar
Old93junk
Have you done a compresion test yet? check the timing/ plug cond./vac. lines/ EGR. Also check the grounds. open the air cleaner/ tubes, once had mice build a nest in air tubes. avehicle thats been sitting that long can have some pretty strange problems.
Old Nov 27, 2008 | 08:19 PM
quicklook2's Avatar
quicklook2
copper or plats?
what the hell are omni spark wires? autozone crap?
the injectors are probably gummed up.
have you checked fuel pressure?
Old Nov 27, 2008 | 08:50 PM
ssquints999
copper, omni spark are oreilly house brand used them before with no problems. how do i check my fuel pressure. how can the injectors be gummed up after running bg 44k
Old Nov 27, 2008 | 09:02 PM
quicklook2's Avatar
quicklook2
gummed up from sitting 2 years.
i would use motorcraft wires.
do you have a manual?
Old Nov 27, 2008 | 09:13 PM
ssquints999
will it just get cleaner as i drive it or what
