Sponsored by: Real Truck
Cold start problems
Old Nov 27, 2008 | 01:06 PM
radargod's Avatar
radargod
Cold start problems
Hey all,
I have a '99 Powerstroke that doesn't like to start when cold. I've replaced the glow plugs and relay...still no luck. If I plug in for an hour it starts. My Chilton says that the PCM gets an input from the Oil temp sensor, could this be the problem?
The only code it's throwing is P603 on a Superchips tuner.
Thanks
Radargod
Old Nov 27, 2008 | 03:04 PM
rbaker6336's Avatar
rbaker6336
could be a batery issue
you would be better to post in the 7.3 forum https://www.ford-trucks.com/forums/forum31/
Old Nov 27, 2008 | 04:25 PM
radargod's Avatar
radargod
Yeah, I'm new to the site...didn't know about all the different forums.
What makes you say battery issues? But I also have door lock problems. Are they tied together you think?
Old Nov 27, 2008 | 04:33 PM
rbaker6336's Avatar
rbaker6336
the door lock problems and batteries can be tied together,mine were but not always true
batteries have to maintain 10.5 volts while starting
when you plug it in the engine wil start easier taking less out of the batteries
so basically a battery and alternater check is about first to do
P0603 may just mean the battery was disconnected
Old Nov 27, 2008 | 04:55 PM
radargod's Avatar
radargod
Does it mean that there's not enough juice to power the GP's? But still turn over the engine? I know I have a weak battery, but since the gp's engage first I hadn't thought that was the problem.
I really don't trust autozone to check the batteries...can I check them myself with a multi-meter at start-up?
Thanks again.
Old Nov 27, 2008 | 05:07 PM
rbaker6336's Avatar
rbaker6336
yes you can check them somewhat,put volt meter on right battery and have someone try to start it.Voltage while starting has to be at least 10.5 or it won't fire the injectors
the glow plugs stay on about 2 minutes even though light goes out earlier
Old Nov 27, 2008 | 09:00 PM
msgtg's Avatar
msgtg
LOL! My 03 doesn't like to start in the cold unless its plugged in.
Keep a couple of things in mind....number 1 you're already concerned about your batteries...number 2 when the temps drop your oil gets thick which puts an extra strain on your starter, your batteries, your whole motor! Plug it in!
I plug mine in when I walk my dogs for the last time before we call it a night and unplug it before I fire it up in the morning.
Joe
Old Nov 28, 2008 | 02:07 PM
uponyou21's Avatar
uponyou21
ended up being my alternator was only kickin out 9.3 volts lol im surprised i made it home from the auto parts store lol
