Sponsored by: Auxito
engine tick
Old Nov 27, 2008 | 12:09 PM
6.9 Diesel's Avatar
6.9 Diesel
engine tick
Hi, I have a 2003 f-150 4.6 2wd crew cab, and i had recently purchased this vehicle about a month ago, and just recently i had noticed that there is a tick coming from the passenger side of the motor, not very educated on these engines, im assuming its a valve tick? just changed the oil with motorcraft 5-20 synthetic, and motorcraft filter, seems to happen every now and then, and goes along with the rpm range, also i had put in a can of seafoam fuel system cleaner with a full tank of fuel if that makes a difference, any help is appreciated. thnkyou
Old Nov 27, 2008 | 12:44 PM
firefighter1416's Avatar
firefighter1416
check your exhaust manifold bolts i bet you have a stud or 2 broke off
Old Nov 27, 2008 | 01:12 PM
Bobby82490's Avatar
Bobby82490
^^X2^^ I have a few rotted off studs, and it makes a real light tick.. sometimes its louder than other times.
