Sponsored by: Kumho
will this work for leveling?
Old Apr 17, 2002 | 01:27 PM
92Custom's Avatar
92Custom
I was gonna go with leveling springs, bushings, drop brackets, etc on my 1992 F150 4x4...
but that is just too much work and money when I am doing it strictly for looks. This is a commuter truck that rarely goes off road.
so...
Can I just remove the stock blocks under the rear springs - it looks like that should level the truck out, and I would think that the springs would be capable of handling anything that I throw at it.
has anyone done this? I know that I need shorter U-bolts. How do you make sure that you have kept the axle in line?
thanks,
Matt
Old Apr 17, 2002 | 04:16 PM
Yeti's Avatar
Yeti
>that I throw at it.
The blocks are there basicly to increase payload, when you add wheight it would level rather than sag.
Should be no problem unless you haul heavy stuff.
There are center bolts that hold the spring pack together and a hole on the spring perch of the axle, the bolt head fits in the hole and the U bolts holt it form moving. Just keep the U bolts as tight to the spring sides as you can , when cranking them down
Old Apr 17, 2002 | 04:27 PM
fordtrck302's Avatar
fordtrck302
