Sponsored by: Real Truck
Jerking when stopping
Old Nov 27, 2008 | 07:49 AM
Downriver Thunder's Avatar
Downriver Thunder
I don't know if it's the nature of the beast or something wrong. I've only had this truck less than a week. When I come to a stop the truck kind of jerks back and forth when it stops. I don't know if that's the way it is or there's an issue with the brakes. I know the ole X didn't do it but that was much heavier.
Old Nov 27, 2008 | 09:45 AM
aldridgec's Avatar
aldridgec
what truck?
Old Nov 29, 2008 | 07:37 AM
Downriver Thunder
Oh, sorry, my bad. 2005 F-250 FX4. It jerks back and forth like there's play somewhere.
Old Nov 29, 2008 | 01:45 PM
Rongold's Avatar
Rongold
Question Jerking ????
By "jerking", do you mean the brake pedal pulsates and/or the steering wheel shakes ??? If that's what you mean by "jerking", then you most likely have one or more cracked, warped, or rotted brake rotors. Be a little more specific---where do you feel the "jerking" ?????
RON
Old Nov 29, 2008 | 01:54 PM
Fordfanatic4life's Avatar
Fordfanatic4life
yea my guess would be a warped rotor/s...
Old Nov 29, 2008 | 05:05 PM
krejci.mike's Avatar
krejci.mike
push the clutch in
Old Nov 30, 2008 | 12:20 AM
dstig1's Avatar
dstig1
Might just be the normal bounciness in the suspension of a 3/4 ton truck, unloaded. Depends how much you are seeing. If it is just a slight bounce fore and aft, then it is probably the same thing I see. I have assumed it to be normal for a stiffly sprung truck, but I suppose it could be worn shocks (though I only have 40k on my 05 F250). But if you are talking severe jerks, then it is probably something to fix...
-Dave
Old Nov 30, 2008 | 07:53 AM
Downriver Thunder
-Dave
That's exactly it, moving fore and aft. I know it didn't do it on my 00 Scurge but that was a much heavier truck. I drive 3 other F-250's here at work but they are 2wd and they don't do it. Maybe it's just a thing with the new truck.
