Modular V10 (6.8l)
Engine Serial Number Trace
Old Nov 26, 2008 | 01:07 PM
spud57's Avatar
spud57
Is it possible to cross reference the engine serial number to a specific year and the VIN of the vehicle it came out of?
I purchased a used V10 engine that was supposed to have 90,000kms and an EGR. The shop putting it in said it did not have an EGR. Now I'm concerned I did not get the engine I was supposed to.
Old Nov 27, 2008 | 12:07 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Not sure if a dealer can do that... might be able to.
If the sticker is on the valve cover, it should have the date of manufacture on it.
One thing. If the original motor was a '99, it's "non-PI" and usually has an EGR.
There are V10s from 2000-2004 that DO have an EGR, but have PI heads. Look at the side of the head near the rear of the engine, and it should have a "PI" cast into the heads if it's a 2000-2004 2-valve engine.
The ONLY difference between EGR and non-EGR is the intake (and possibly, only the throttle body where the EGR connects to it) and the driver's side exhaust manifold.
So, it should be quite easy to get an EGR motor to work with non-EGR. Just keep the original PCM.
Old Nov 28, 2008 | 01:19 PM
spud57's Avatar
spud57
Yes you can
The Vehicle Information Sheet has the engine SN. The SN is on the valve cover sticker.
The Vehicle Information Sheet also has other info such as build info, sale info, and installed options.
DarkStarMedia
Nov 28, 2016 07:34 PM
ed foster
Jul 26, 2016 11:30 PM
fancyvern
Apr 28, 2016 12:34 PM
Bill in Bama
Nov 19, 2015 06:13 PM
Marco Venegas
Aug 29, 2014 08:08 AM
