Sponsored by: Kumho
gears on '95 PSD
Old Apr 23, 2002 | 05:24 PM
jelrod_tn's Avatar
jelrod_tn
gears on '95 PSD
21-Apr-02, 07:40 PM (EST)
I'm the proud owner of a 2wd '95 F250 PSD and I was wondering how you tell the gear ratio. I looked on the rear axle and found this on a little black tag:
5S125K
55 10 2 5 C 13
In comparison to other gear ratios, how good is that?
thanks!
Old Apr 23, 2002 | 10:39 PM
Cope's Avatar
Cope
gears on '95 PSD
I can't tell from those numbers unless there is a 3 in front of the 55 you mentioned. In that case it would be 3.55. Look at the code under the word axle on the sticker on the door jam. Then do a search for ford axle codes or post what number it is and somebody should be able to tell you. This should solve your problem.
-Cope
95 F-150 4x4
4.9L M5OD
Front Truetrac Rear Detroit
3.73 Precision Gears
Warn Premiums
4" Superlift Superunner
Old Apr 25, 2002 | 07:04 AM
cpnhgnjnky's Avatar
cpnhgnjnky
gears on '95 PSD
