lead substitute? i heard that instead of useing that expensive lead substitute in your gas you can use some transmission fluid? has any one else heard about this and if you have witch kinds can you use and how much? any info on this would be great.
Transmission fluid is a hydraulic oil. It is simply a light oil that has some extreme pressure (and other ) additives for use in hydraulic motors, pumps and actuators.
It was never meant to be burned in a combustion chamber.
If it is burned, it leaves some pretty nasty combustion products that you absolutely do not want sticking to your valves, valve guides, tops of your pistons, and in your top piston ring grooves.
If most of those retail fuel additives were so beneficial then why do engines that run on propane run so much cleaner and last so much longer than engines that run on gasoline? (it's just about impossible to use fuel additives in a propane powered engine)
Use transmission fluid in your transmission.
Leave gasoline additives on the shelf.
They only seem to be suggested and promoted by, and are only benefit to those who sell them.
Instead of looking around for a lead additive, you might try looking around for some different mechanics....lol
As has already been stated, you don't need to add anything. If your "mechanic" gives you grief about it tell him you will be sure to bring the engine to him when it wears out from running unleaded (I hope he doesn't hold his breath though)
In the late 80's or early '90's I would put some in each fillup if I remembered. Then in the late 90's when I first latched on to FTE, it was email based forum back then, we had a discussion about lead and it was told by men far smarter than me our trucks do not need it, UNLESS you are doing heavy hauling daily in extreme (hot, dusty, etc) conditions or racing or putting a lot of stress on your engine then you do not need lead additives.
I have not used lead in my engine since at least 1996 and I have not had any problems, no knocks, no pings, no smoke...
hmmmmmmmmmmmmmmmmm ok than. you said UNLESS you are doing heavy hauling daily in extreme (hot, dusty, etc) conditions. what would be considered extreme hot.
You need hardened valve seats if you want your seats to last 100,000 miles under constant heavy load, like an over-the-road hauler, pulling a heavy trailer all the time, etc. Even then it is real questionable if a lead substitute would provide a benefit.
If it's dusty, your best bet is to go to a paper filter instead of an oil bath.
