I'm try to put a 74 f150 together im putting a 390 and a np435 in it Im in need of the motor mounts on the frame I can buy the rubber mount at the part store but I need the main mount on the frame who ever pulled the original engine took the mounts also. I search classifieds didnt find anything. If someone has a 67 to 76 that had a 360 or 390 I need the mounter mounts on the frame let me know Im ready to get this thing going thanks
From 1965 until 1979 there are 3 sets of engine perches for 2 wheel drive F100 through F250.
Set one fits all inline 6 and all FE engines.
Set two fits 289,302,351w, 351c, 351m, and 400.
Set three fits 429 and 460.
Bill, the reason for the different part number is the left perch has a slight bend in it for some reason unknown to me. However it still does the same thing.
Mike
Yep, everyone is correct.
And I believe the slight bend and different part number thing is due to the dent sides needing to fit around the Saginaw PS gear box?
I have these available for the 1965 - 1972 F100/F250, 1967 - 1972 F350 application and also the "bent" ones for the 1973 - 1976 F Series.
I would also speculate that the in line six mounts from 1977 - 1979 2wd F Series would match up to that FE engine just fine?
Thank ya for the input I really never thought the 240-300 mounts would be the same or that all those years were the same that really widens my search if anyone has a pair on had let me know thanks again
I think I have a set if you are interested. They came out of a 73, 2wd camper special with a 360. I parted the truck a while back, but I'm pretty sure I have the motor mounts somewhere still. If you want I can see if I can locate them and get you some pics and a price. PM me if interested.
