Factory clock schematic?
Old Nov 25, 2008 | 07:39 PM
uncle.stosh's Avatar
uncle.stosh
I need to check a couple out of the truck and was wondering if anyone knew the pin outs on the plug.
Old Nov 26, 2008 | 05:57 AM
rocktown1980's Avatar
rocktown1980
is the digi-clock? and how many pins do you have on the clock? i dont have a schematic but i am quite electronic savy. i might be able to help, i hope
Old Nov 26, 2008 | 09:05 AM
LARIAT 85's Avatar
LARIAT 85
Dude, what the hell are you talking about?
Old Nov 26, 2008 | 10:08 AM
Franklin2's Avatar
Franklin2
Next time you are in the junkyard, cut the pigtail off. All I have is the wire colors, no pin numbers.
The power wire is the lightgreen/yellow. This feeds the courtesy light circuits too.
The key on power is the white/pink.
The brown wire is the good old running light wire. This must dim the display when the lights are turned on.
Then you have a black ground.
Ford testing I would twist the lightgreen/yellow and the white/pink wires together, and hook them to + and the black to -.
Old Nov 26, 2008 | 11:27 AM
ri_truck_guy's Avatar
ri_truck_guy
I've got a full wire harness and clock out of the truck. No pin numbers on either of the connectors. They will test out just like Dave said. I've used finishing nails inserted in the female connectors in the the plug, then hooked the nails up to a small 12 volt battery charger. Works like a charm.
Old Nov 26, 2008 | 12:16 PM
uncle.stosh
Thanks guys.
I do have a pigtail that I'll be hooking up to a 12VDC power supply.
The colors and use is just what I needed.
BTW: some clocks are hard wired to the harness, and some use a small pigtail that plugs in near the heater control.
Old Nov 26, 2008 | 01:05 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Another wiring difference is the 1980-1982 clock has a Blue/Red wire instead of the brown wire, because the 1980-1982 clock has a dimmable backlight that uses the circut from the instrument cluster illumination.
shouldn't affect testing though.
Old Nov 26, 2008 | 05:12 PM
uncle.stosh
I just needed a quick way of testing these when I get them from the yard without having to plug them into my truck.
I'm in the process of converting a PC Power supply to a nice regulated power supply for bench testing.
Bearhugger1933
May 31, 2017 10:59 AM
Jons13
Aug 4, 2016 12:28 PM
Sdean
Mar 13, 2016 06:23 PM
racin
1997 - 2003 F150
Nov 22, 2015 07:40 PM
Skybang
Large Truck
Nov 19, 2015 05:27 PM
