Bronco II Ford Bronco II
Speedometer Cable Replacement 1990 Bronco Ii
Old Nov 25, 2008 | 10:56 AM
EAGLESBEAK's Avatar
EAGLESBEAK
How do I change the speedometer cable ? Does anything need to be done under the dash, or can it just be disconnected at the firewall ?
Old Nov 25, 2008 | 01:11 PM
87 XLT's Avatar
87 XLT
If your cruise control is also not working, you probably just need to remove the VSS/vehicle speed sensor from the side of the trans & replace the broken plastic gear.
Been there & done that 2 times on my 87.
Old Nov 25, 2008 | 11:45 PM
rebocardo's Avatar
rebocardo
For an automatic, have to remove the speedometer, squish cable end to remove from the head. Then remove from transfer case, and pull down. Standard is a bit more complicated if you have cruise, same procedure though.
lisagoud
WTB - Parts & other
Jun 18, 2017 11:24 AM
swoosh1958
32
Feb 11, 2017 04:42 PM
bradphx
Oct 12, 2016 04:07 PM
rashanny
24
Mar 31, 2011 11:14 PM
