66 SPEEDOMETER CABLE
Old Jan 25, 2017 | 03:20 PM
swoosh1958's Avatar
swoosh1958
My 1966 f100 is sitting on a 79 f150 frame, it has a C6 transmission. Will the speedometer cable screw right into the 66 dash? Or are there different ends that are needed?
Old Jan 25, 2017 | 05:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No.
1961/72: The cable threads into the back of the speedometer.
1973/79: The cable is retained to the speedometer w/a clip.
Old Jan 26, 2017 | 07:05 PM
swoosh1958's Avatar
swoosh1958
One end is already connected to the transmission, it has a retaining clip. The other end looks like the image on the left. Does that look right?
Old Jan 26, 2017 | 08:57 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Seems OK from here. The back of the sweep speedometer is a threaded connection. If I put calipers across the threads it is 5/8".
Old Jan 27, 2017 | 03:11 PM
swoosh1958's Avatar
swoosh1958
Cool! Thanks for the info and pics guys.
Old Jan 29, 2017 | 03:17 PM
NumberDummy
The clip retains the nylon speedometer DRIVEN gear to the cable.
Old Jan 29, 2017 | 06:27 PM
swoosh1958's Avatar
swoosh1958
This is similar to the connection on the transmission. The other end has a threaded ferrule. NumberDummy, you are saying I am missing a plastic clip, that clips on the ferrule and back of speedometer?
Old Jan 29, 2017 | 06:39 PM
swoosh1958's Avatar
swoosh1958
This supposed to be a 1966 speedometer cable. I only see a grommet. Am I missing something here NummberDummy?
Old Jan 29, 2017 | 06:51 PM
swoosh1958's Avatar
swoosh1958
I read your post again. Sometimes, I'am so stupid. Argh!
Old Jan 30, 2017 | 05:46 PM
swoosh1958's Avatar
swoosh1958
So guys, It threaded right on. Took it for a spin and the needle pegs out.Do I need a different gear on the transmission side? Do I need a custom cable? Thanks for your help.
Old Jan 30, 2017 | 06:14 PM
53deere's Avatar
53deere
Isn't your cable connected to the transfer case?
Old Jan 30, 2017 | 06:39 PM
swoosh1958's Avatar
swoosh1958
53deere, you are correct! Uhm! Had to go look.
Old Jan 30, 2017 | 08:19 PM
TA455HO's Avatar
TA455HO
Lead Gopher
The speedometer cable itself turns - from end to end - in a 1-to-1 ratio. Meaning for every rotation at the transmission/transfer case end it will rotate one time at the speedometer head. This is always the case. The way that the speed of rotation is changed is by using different driven and drive gears at the transmission/transfer case end. There are no changes at the speedometer head itself, only underneath at the lower end. If you pull the cable out there are gears behind it that can be swapped out.
In some cases manufacturers also used small ratio changing boxes that screwed to the outside, too. Here's one example with a quick search of a GM product that changes the ratio by a factor of 1.3-to-1. This is separate from the driven and drive gears which provide for some variations. Just an example of what they sometimes did. The right (wrong?) combination of rear-end gear ratios, transmission/transfer case and tires can make for some interesting approaches over the years.
CUCV / GM TRANSMISSION SPEEDOMETER CABLE DRIVE ADAPTER 1.3 RATIO TRUCK [C4S4] | eBay
Old Jan 31, 2017 | 03:08 PM
swoosh1958's Avatar
swoosh1958
TA455HO,Have I jacked my speedometer already? It pegged out immediately!I wonder if anyone knows the correct gear for this? 1979 f150, C6 4x4 to the original 1966 f100 speedometer.
Old Jan 31, 2017 | 03:50 PM
TA455HO's Avatar
TA455HO
Lead Gopher
If you go very slow and it is pegged at 100 MPH or higher then no amount of gearing changes would solve that, I wouldn't think. Not sure what might cause that other than the speedometer head itself, perhaps, but that's just a guess.
Chad
