33x12.5x16.5 or 285/75/16 on a 2001 Supercrew???
[updated:LAST EDITED ON 26-Apr-02 AT 09:29 PM (EST)]Ok, I know about Superduties, but I'm just learning about the Supercrew so I need some help.
My girlfriend has a 2001 Supercrew 4x4 with the torsion bars cranked up to level the front of the truck. She's looking to get new rims and tires. Should she get 33x12.5x16.5 with a 16.5x9.75 rim or 285/75/16 with a 16x8 rim? Will she have problems fitting either? What are the pros cons of the two? I know that the 285/75/16 tires are more expensive and are a little narrower, but other than that??? What do you guys reccommend? Or should I go with 305/70/16? 16x10 rims? Thanks for the help.
the 33s will rub big time!! i have a 97 f-150 4x4 flareside with a 4 inch suspension lift and i have 33 bfg mud ta's on 16.5x9.75 weld rims and i still rub on my mud flaps. get the 285s on a narow rim and you should be ok. cranking up the torsion bars BAD IDEA!!!
bed there done that!!!
tony
tony
f100today
01-16-2013 06:04 PM
pintoches
06-23-2011 04:05 PM
