dana 60s
Old Nov 24, 2008 | 11:23 PM
farmer ford's Avatar
farmer ford
dana 60s
putting a cummins in a 79 f250. do i need the dana 60 front and rear or just front? what about the newer ones with ball joints instead of king pins? thanks ahead of time for help
Old Nov 24, 2008 | 11:36 PM
masterbeavis's Avatar
masterbeavis
If you have the money, put a 60/70 combo in your truck. I have seen the 6.9/7.3 on TTB D44s, you might be able to get away with it on a solid axle 44 as long as you dont do any jumping with the truck. if you can get the 60 front to bolt up to your truck somehow, it doesnt matter if it is kingpin or balljoint. The balljoint axle is 100% fine for 99% of the people out there.
Old Nov 25, 2008 | 01:24 PM
Tha_Stepside's Avatar
Tha_Stepside
I agree, a 60 axle out of a 78/79 would bolt right in as long as you have the correct gear ratio. The D60 rear is about as strong as a 9" either a sterling 10.25 or D70 back there would do the trick.
Old Nov 25, 2008 | 02:15 PM
ChaseTruck754's Avatar
ChaseTruck754
What axles are in the truck now? I'd think a D44 front and D60 rear - which should hold up fine if you're not towing 10k lbs. or racing it.
Old Nov 27, 2008 | 11:07 AM
farmer ford
the tag is missing on the front so until i have time to tear it down to read the stamp i wont know for sure. it is eight lugs which is good. worst case senario it breaks then find the D60. thanks guys.
