part number needed
Old Nov 24, 2008 | 08:09 PM
rat49f6's Avatar
rat49f6
part number needed
does anybody have a part number for the three drive shaft u joints and the carrier bearing for a 49 f6 v8???
Old Nov 24, 2008 | 09:47 PM
Julies Cool F1's Avatar
Julies Cool F1
Stupid site quirks!
Well I had this all typed in and pushed "go advanced" and it farted away into dust.
Lets see, F6 (not a school; bus or COE) is a "TH" so.......
I have the picture right in front of me from page 140 of the 48-52 Truck Chassis Parts Catalogue because I'm still looking for the stupid 48-52 Cowl Vent drawing...gripe gripe.... Here are the numbers on the page - again...gripe gripe:
Kit, (Universal Joint) for T, Th,....(with 4 speed spur gear transmission), "Consists of the following - 4 beaings, 1 spider & 4 snap rings, 01T 7039.
Your carrier bearing which I have always (probably incorrectly - huh, Bill) called a "thrust bearing" comes in four pieces. From front to rear they are:
"Felt, Sleeve & Collar ***'y (Coupling Shaft Support)-Front" 01T 4832.
"Sleeve (Coupling Shaft Support)-Center" 01T 4826-A.
"Bearing (Coupling Shaft Support)-Center" 01T 4812.
and,
"Felt, Sleeve & Collar ***'y (Coupling Shaft Support)-Rear" 01T 4833.
If you need me to scan in the drawing, let me know. Number Dummy will probably be here soon to check my work! Judge Judy's on so I thought I'd let him take a break for 30 minutes
Best,
Julie
Old Nov 25, 2008 | 08:48 AM
rat49f6's Avatar
rat49f6
i would love a scan of the pics ... rat49f6@hotmail.com
are these parts something i could cross referance to napa numbers???
ps u guys are amazing ! i hope someday to have half of ur useful knowlegde
Old Nov 25, 2008 | 02:19 PM
Julies Cool F1
One picture is worth 1000 words!
Here ya go! It's in my #2 gallery if you want to look at it here (anyone). I'll e-mail you a copy too so you can view it and print it in it's original size!
Julie!
Old Nov 25, 2008 | 04:37 PM
rat49f6's Avatar
rat49f6
What r felts?
Old Nov 25, 2008 | 09:42 PM
Julies Cool F1
Originally Posted by rat49f6
What r felts?
Dust covers/grease seals!
J!
Old Nov 26, 2008 | 10:16 AM
rat49f6's Avatar
rat49f6
So I called napa today...
First I gave them the year make model and parts I wanted he stated"1/2 ton" I said no 2 ton he said "1 ton?" I was like no f6 its a 2 ton... he then said well that's not a pickup at all I was like no its a stake body/dumptruck ...he. just paused
I was like maybe u can cross referance the original part numbers? He said "sure let's try"
I give him one of the numbers and he was likke that's it ...that's the whole number and reads it back... I was like yes sir. And again he just paused ...then he says it must be dealer only and says sorry I couldn't help ...hangs up
So while in a perfect world ur info was great (julie)
Can anyone help me with a napa or brand number ... I really don't wanna pay to have it rebuilt
Thx again and thx in advance
Old Nov 26, 2008 | 09:12 PM
KJLYPW's Avatar
KJLYPW
Any good industrial parts supplier should be able to fix you up, just take in the old u-joints measurements - overall across both ways, and diameter of caps. They can look up a good aftermarket part number based on the dimensions. Hope this helps
Old Nov 27, 2008 | 04:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
2) B5TZ4635A .. U-Joint / Spicer Type / 1350 Size
1) C5TZ4635G (Replaced: B6TZ4635B) .. U-Joint / Spicer Type / 1410 Size
1) C3AZ7025B (Replaced: 8A7025 & 01T4812) .. Carrier Bearing / Bearing Industry Part Number: 207L
Obsolete Ford parts vendor Green Sales Co. in Cincinnati OH has ALL these parts: 800-543-4959
1) 01T4826B (replaced 01T-4826-A) .. Sleeve / Wesley Obsolete Parts in Liberty KY has TWO: 606-787-5293
1) 01T4832 .. Felt, Sleeve & Collar Assy-Front / Miller Obsolete Parts in Binghamton NY has FIFTEEN: 800-546-7278
1) 01T4833 .. Felt, Sleeve & Collar Assy-Rear / Miller Obsolete Parts in Binghamton NY has SEVEN: 800-546-7278
Julie, Ford changed all the U-Joint basic part numbers from 7039 to 4635 in 1957, which rendered all those old numbers very hard to track down.
This F6 uses three U-Joints, one is different than the other two. Two are listed under the driveshaft (4602), one is listed under the coupling shaft (4817).
Ford also changed the carrier bearing basic part number.
While the 1948/56 Ford Truck Parts Catalog has the new numbers listed, some of these part numbers have been updated, as you can see.
Because of Ford's penchant for updating part numbers, I have to verify every *^&%^^ part number to see if it has been updated, before it's posted.
This includes every part number thru today!
Old Nov 27, 2008 | 12:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You can also look here:
www.neapco.com/n_products-catalogs.php?pdffile=2
Old Nov 27, 2008 | 12:19 PM
havi's Avatar
havi
I'll have the Roast Duck
We have a Driveline Specialists place nearby up here that has all the u-joints and other similar parts and are competitively priced with Napa and other chain stores. Maybe look up to see if one is in your area?
Old Nov 27, 2008 | 12:44 PM
Julies Cool F1
2) Julie, Ford changed all the U-Joint basic part numbers from 7039 to 4635 in 1957, which rendered all those old numbers very hard to track down.
That figures!
I figured you'd "cover my six" on this Bill.....But thought I might try to give him something to start with...at least the drawing is good (even though the numbers aren't)
I'm not sure about the U-joints, but the bearing will have a number on it that they can match to a new bearing - hopefully it isn't worn off. Usually when they find the bearing in the pubs, it will also list the other parts/felts.
I wouldn't think that the U-joints would be hard to find, but like Havi suggested, maybe a shop that specializes in drive trains could help. They usually have the older parts lists on the back shelves.
I used to really like NAPA, but in the past couple years they have really gone down the tubes. Your are lucky your guy at least spoke english...
J!
Old Nov 27, 2008 | 02:21 PM
NumberDummy
J!
I used Ford Obsolete-Supercede-Interchange catalogs to update the part numbers and found ALL the parts NOS.
The bearing went from 01T4812 to 8A7025 to C3AZ7025B.
The two u-joints you posted, went from 01T7039 to B5TZ4635A.
The sleeve you posted: 01T4812A went to 01T4812B.
The 1948/56 truck parts catalog lists all the u-joint specs, but it took almost an hour to research, locate and type all that jazz, so I didn't have the time to post them.
The carrier bearing may have a number on it, but if it's the original, the Ford part number was changed 51 years ago, so what are the chances of finding it under the bearing industry number?
The bearing I posted has an industry number: 207L, which I also listed.
The problem with old parts catalogs is, they contain old part numbers. These numbers must be cross referenced to find out if they have been updated or not.
Old Nov 27, 2008 | 02:57 PM
rat49f6's Avatar
rat49f6
i do have a great shop close by but im using napabfor a few reasons
the budget is zero i can trade my overtime hours for parts ... no money exchanged no money spent in my mind
and i love saying i did it myself
i figure as long as i mark thing and line the new up it shouldnt vibrate hope to not be wrong if it does ill have them balance it
rat49f6
29
Sep 26, 2019 04:57 PM
F-1
Feb 15, 2017 07:50 PM
Thedonk
Aug 13, 2016 10:52 PM
TallPaul
Electrical Systems/Wiring
52
Aug 12, 2008 10:34 AM
05chop
Apr 24, 2008 06:26 PM
