Ball Joints?? Quality Question...
Old Nov 24, 2008 | 06:13 PM
afonda's Avatar
afonda
What is the difference between pro grade and non pro grade??
Also, should they be greasable or not?
Also, what about aftermarket parts instead of Motorcraft?
Old Nov 24, 2008 | 06:27 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
You should go with the Moogs. They are greaseable and far superior to other brands.
Old Nov 24, 2008 | 06:35 PM
swaybar's Avatar
swaybar
my guess would be "non pro" are just for street drivin and no 4wheelin-plowin-or pullin. but i just did my upper and lowers one month ago and wasn't sure to go with the moog's or a less expensive brand to save money but decided to get the moogs which cost the most. me and a buddy did them and now that there done i'm so glad i went with the best-don't want to have to do them again any sooner than they might need to be done.
Old Nov 25, 2008 | 12:52 AM
USAF CCM's Avatar
USAF CCM
Don't forget the Dana Spicers from NAPA. I was impressed with their quality and recently installed theirs with zerk fittings. Always remember and never forget.....grease the uppers then remove the zerk and install the cap BEFORE installing them on the vehicle. I know, my left side has the cap in the upper but the right side has a sheared off zerk which I covered with some RTV.
Old Nov 25, 2008 | 06:06 AM
4EXTRDR's Avatar
4EXTRDR
I too went with the Dana/Spicers with the grease Zerk...They appear to be good quality and through Rockauto....were half the price of Moog's.
Old Nov 25, 2008 | 08:14 AM
mueckster's Avatar
mueckster
I put a straight fitting in the top ball joint, just like the bottom, and used this type of adaptor to grease it. Name:  grease fitting adaptor.jpg
There is plenty of room for the small straight fitting and doesn't need to be removed.
Old Nov 25, 2008 | 09:09 AM
SGnAZ's Avatar
SGnAZ
Originally Posted by mueckster
I put a straight fitting in the top ball joint, just like the bottom, and used this type of adaptor to grease it. Attachment 12109
Where did you get that adapter? That is exactly what I need.
Thanks.
Old Nov 25, 2008 | 09:10 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Would you tell us who makes that adapter, and where you got it? Thanks!!
Old Nov 25, 2008 | 10:12 AM
BigJake34452's Avatar
BigJake34452
X2 on the moog ball joints. good stuff.
Old Nov 25, 2008 | 11:39 AM
mueckster's Avatar
mueckster
I purchased the grease fitting adaptor from a local independent parts store. It is made by Lincoln, part #5883. You may find it an ag supply store, i.e. Tractor Supply Co. or at one of the other parts store chains. I placed the adaptor on an old tire chuck that I removed the end and put a grease fitting on the female end. I can put this riggin' on my regular grease hose and reach up into the axle above the U-joint and snap it on the grease fitting.
Old Nov 25, 2008 | 11:41 AM
Kwikkordead's Avatar
Kwikkordead
I want to know where to get that adapter too. It's just what I need for my upper ball joints.
I bought mine from Ford and they were equipped with zerks.
Old Nov 25, 2008 | 11:50 AM
mueckster's Avatar
mueckster
Northern Tool & Equipment is a distributor for Lincoln lube products.
Old Nov 25, 2008 | 01:52 PM
SGnAZ's Avatar
SGnAZ
Thumbs up
Thank you very much.
Old Nov 25, 2008 | 02:09 PM
cj99's Avatar
cj99
I got mine from Grease Gun Accessory Kit - TP Tools & Equipment. If you call them you can buy just that tip. But that is a nice set to have around. The push on tip works good for some u-joints, like front driveshaft to front axle.
