bat. disconnect and inductive flash ?
Old Nov 23, 2008 | 05:10 PM
6LPSD's Avatar
6LPSD
Question bat. disconnect and inductive flash ?
hey guys got my truck back from the dealership 2 weeks ago, and had the egr cooler replaced, oil cooler replaced, egr valve, all coolant hoses replaced, new degaus bottle, and engine flushed 3x to get oil out of cooling system, when the dealer did all of this he disconnected the bats for 2 days, had to reset clock. will the bat. disconnect mess & delete the inductive heat flash i had at my other dealership be erased from the ecm after all this was done, i would hate to go back to my other "stealer" and have them flash my truck all over again. thanks guys for the help.
Old Nov 23, 2008 | 05:14 PM
PowerStrokeHD's Avatar
PowerStrokeHD
You are good. Disconnecting the batteries will not cause you to lose a programming flash. If it did, your truck would not run at all...
Old Nov 23, 2008 | 05:23 PM
6LPSD's Avatar
6LPSD
ok thanks for the help man, i did not know if the flash was "burned" or unremovable into the ecm or just a light "surface flash" like a sct or programmer file.
