Battery life?
Old Nov 23, 2008 | 05:03 PM
dbone82's Avatar
dbone82
Battery life?
<TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNSELECTABLE="on"><TBODY><TR height="100%" UNSELECTABLE="on" width="100%"><TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNSELECTABLE="off">It's getting cold again, and I'm wondering how much life I should expect out of the batteries in my 2002 F-250 with 7.3 powerstroke. The batteries are original, and I just had to charge them for the first time ever. The truck sat for two weeks without starting this time. How do you know if it's just cold out, or if the batteries are going bad?
Thx.
Dave
</TD></TR><TR UNSELECTABLE="on" hb_tag="1"><TD style="FONT-SIZE: 1pt" height=1 UNSELECTABLE="on">
</TD></TR></TBODY></TABLE>
Old Nov 23, 2008 | 05:10 PM
F350-6's Avatar
F350-6
Welcome to FTE Dave. You can get your batteries load tested for free at the auto parts stores. I'd guess you've reached the end of the life of your factory batteries. You might be able to get by for a while just keeping them charged up, but with the glow plugs pulling the extra power during winter, I'd say you're probably better off just changing them.
Just make sure to replace both batteries at the same time, or the old battery that you don't replace will pull down the new battery.
Old Nov 23, 2008 | 05:13 PM
Izzy351's Avatar
Izzy351
I had to replace mine last spring ('07), and I have an '02 also.
Old Nov 23, 2008 | 05:23 PM
rbaker6336's Avatar
rbaker6336
If you had to charge the batteries after sitting 2 weeks they have probly had the lick unless you have something drawing on them
normally when I charge a battery it is to get the vehicle to the battery store unless I can find another gremlin that is causing the problem
if they are getting bad it's best to replace them,otherwise you are stressing alternater and starter
Old Nov 23, 2008 | 05:48 PM
UP_There's Avatar
UP_There
6 years on batteries ain't bad! I would say they are most likely toasted! Even if they load test okay, 6 years is well beyond the normal life of batteries. I would replace them if it was me......just for peace of mind!
Old Nov 23, 2008 | 05:55 PM
Steve_250's Avatar
Steve_250
The batts in my '03 lasted almost 6 years. You've had your's for 7, they have given you all they had, time to recycle them. Just hope the next ones last that long...
Old Nov 23, 2008 | 06:52 PM
Dodger12's Avatar
Dodger12
7 1/2 years on mine orignal batteries
Question, Whats harder on the battery, lots of starts or the age of battery.
I only have about 72K on my truck.
Old Nov 23, 2008 | 07:14 PM
rbaker6336's Avatar
rbaker6336
Actually heat and viberation are the biggest battery killers
Guess the heat part is why none of my origonal batteries have lasted over 3 years,and have never had sort of a bad battery,they were either good or grave yard dead
