help carb rebuild question
Old Nov 23, 2008 | 02:07 PM
t3hranger's Avatar
t3hranger
Exclamation help carb rebuild question
its a 79 f-100 custom
300 inline 6
single barrel carb
the carb says autolite on it and the rebuild kit is for a carter carb are these the same thing or will the kit work????
just wanted to know before i take the carb apart and open the box and then need a different one and cant take it back cuase its been opened.
thanks for your help!
Old Nov 23, 2008 | 02:21 PM
fmc400's Avatar
fmc400
MSEE
Autolite and Carter 1 barrels are completely different, unless it's a branded version. Do you have a picture of the Autolite?
Old Nov 23, 2008 | 02:23 PM
t3hranger's Avatar
t3hranger
umm nah i can take with my phone but let me check it i think its an autolite 1101 and see if i can get a good pic
Old Nov 23, 2008 | 02:26 PM
t3hranger's Avatar
t3hranger
acutally it says motorcraft on it let upload pics as well
Old Nov 23, 2008 | 02:43 PM
t3hranger's Avatar
t3hranger
heres the pics i think it might be a carter but idk
sorry bout small pics, phone camera
Old Nov 23, 2008 | 02:47 PM
t3hranger's Avatar
t3hranger
bump for justice
Old Nov 23, 2008 | 02:51 PM
pfogle's Avatar
pfogle
The should be an ID tag with numbers on it. If you take those numbers into the parts store they will be able to get you the right rebuild kit.
Old Nov 23, 2008 | 02:53 PM
fmc400's Avatar
fmc400
MSEE
Sorry man, but those pictures are too small for me to tell. Here is an Autolite 110X:
Let me go out in the garage to get a shot of a Carter.
Old Nov 23, 2008 | 03:01 PM
fmc400's Avatar
fmc400
MSEE
Here is a Carter YFA 1 barrel:
If you look carefully on the front (sometimes hidden by a bracket) on later model Carter YFA 1 barrels, they will say "Made by Carter for Motorcraft." If that's the case it's a Carter. And like pfogle said, just take the numbers off the carburetor and have them cross reference the kit for you. Even if you just say you need a rebuild kit for a Carter carburetor off a 79 Ford, there can be a dozen available kits within a model year.
Old Nov 23, 2008 | 03:03 PM
t3hranger's Avatar
t3hranger
ok well i dont think its an autolite anymore let me look at it more closely and see what i can tell
Old Nov 23, 2008 | 03:05 PM
t3hranger's Avatar
t3hranger
ok now pics work its a carter now i just need to make sure that i got the right kit thanks for all yalls help. i really appreciate it
Old Nov 27, 2008 | 08:33 PM
Tees77f150's Avatar
Tees77f150
Yep. I went through that, It was a Carter, and it had a green tag attached with numbers. I took those numbers to NAPA, and they hooked me up it was just under $20.
Old Nov 27, 2008 | 10:55 PM
masterbeavis's Avatar
masterbeavis
I have had to sometimes bring in the old gaskets to verify (by looking thru the plastic) that the kit I am buying is the correct one. Now if you only have 1 vehicle, and that is the one you are looking at, then no you cannot do that.
