factory 2 wd rim width?
Old Nov 23, 2008 | 11:34 AM
79F150/F600's Avatar
79F150/F600
I'm looking for a set of narrow like 6 -6.5" wide 15 inch wheels for my 4x4 to fit it in the garage for winter repairs and fabricating, and figure my cheapest find for these narrow rims I need would maybe come of a stock 4x2 do any of you know the factory rim width?
Old Nov 23, 2008 | 01:31 PM
Dr. Dirt's Avatar
Dr. Dirt
I'm gonna bump this one to the top cause I need to know the answer to this question, too.
Old Nov 23, 2008 | 01:46 PM
custom1106's Avatar
custom1106
Like these? I believe these are 15x6. You have to watch out though, the hub hole in the center may be different from 2wd to 4wd, same bolt pattern though.
Old Nov 23, 2008 | 01:49 PM
Alvin in AZ's Avatar
Alvin in AZ
It's a Ford.
There were lots of sizes.
Pick one. ;)
My 2wd '75 came with (15") 5+1/2" wide wheels. :(
It was a squirrely-*** sucker right from the start.
Went to 16x7's after wearing out two sets of 15" tires.
Then ran one set of tube type 7.50-16's (without tubes)
and they worked out good. :)
235/85-16-E's now. :)
Alvin in AZ
Old Nov 23, 2008 | 02:01 PM
brentleedragon's Avatar
brentleedragon
the hub centers on a 4x4 are going to be bigger than a 2wd one. You could put 4x4 tires on a 2wd but I am not sure of the other way around at least in the front, I think you'd run into a problem with the hub whole being smaller on a 2wd than on a 4wd truck.
and I believe they were 15x7 or 15x8
Old Nov 23, 2008 | 02:10 PM
79F150/F600
well to better phrase this what I'm looking for is a 15"x6" or 6.5" rim figured they probably put a norrow rim like that on a 2wd truck (ford) if anyone knows for sure if a 2wd rim will fit over a 4x4 front hub it would be much appreciated. It seems from responses allready had 2wd's did come with 15"x6" wheels.
Old Nov 23, 2008 | 02:29 PM
Dr. Dirt's Avatar
Dr. Dirt
the other day I saw an old farm truck. it was a 76 F100 4x2. it had 215-75/R15s.
Old Nov 23, 2008 | 02:44 PM
Alvin in AZ
All I know is mine weren't 6", mine were 5+1/2" and they sucked donkey dick...
...and the bolt pattern is of course 5 on 5+1/2 with a 4" inset. :)
Came with...
H78-15 "car tires" load range C
It's a...
'75 F150
Ford 9"
31 spline axles
Daytona pinion housing
3.25 gear
Traction Loc
3750lbs.
4 gear spider
Alvin in AZ
Old Nov 23, 2008 | 02:57 PM
79F150/F600
Well aside from the fact that not all 4x2's had 15x6" rims my biggest concern is do 2wd rims fit on the front of 4x4 trucks (ford f150 to f150) since I should be able to find 15x6" wheels off a old 2wd ford to fit the 195/55-15 inch tires that are needed to lower my 4x4 enough to fit under the garage door these tires are merely 22.73inches tall and will mount to a rim even as small as 5.5"s
Old Nov 23, 2008 | 03:04 PM
brentleedragon
I dont think 2wd front rims will fit up front on a 4x4 because your 4x4 is going to have a Dana 44 which is going to have a bigger hub then the 2wds hub on the front. So to answer your question I have not see a 2wd rim fit up front on a 4x4 (my rims on my truck were all 4x4, but my 2wd rims did not fit back on the 4x4 truck up front)
4x4's have bigger front hubs than 4x2, they wont fit. If you still think they might just measure the hub spacings
Old Nov 23, 2008 | 03:07 PM
brentleedragon
didnt some of the cars? IE Thunderbird and others have a 5.5 spacing for the lug nuts? you could try those?
Old Nov 23, 2008 | 03:17 PM
79F150/F600
I'm pretty sure crown vics had the same bolt pattern as the little rangers and bronco II's and I'm pretty sure thunderbirds were 4 lug like the mustangs used to be.
Old Nov 23, 2008 | 03:20 PM
brentleedragon
well i meant older ones, my dads 58 tbird had a 5 lug spacing but it might have been the 5 1/4 or i guess 5 on 5 i can not remember
Old Nov 23, 2008 | 03:27 PM
79F150/F600
Well I'm just looking for something somewhat easily found in a junk yard for cheap I will only ever use these wheels to drive in and out of the garage and to the DMV like 6 miles down the road if I get pulled over for being to jacked up which hasn't happened yet(knock on wood) and I heard my truck issupposed to be exempt from lift laws in my state because of the classic registration plates.
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D5TZ-1007-E replaced by D8TZ-1007-J .. Wheel-Use with Tubeless Tires & SRW's / 16" x 5.5" / 6.50" Bolt Circle / Fits: 1973/78 F250 2WD & 4WD / 1973/78 F350.
I never heard of any Ford 4WD using different wheels than 2WD's. If that was true, you'd need to carry two spare tires.
NO Ford or Merc passenger car used a 5.50" bolt circle after 1948 = NONE!
NO Thunderbird ever had 4 lug wheels = NONE!
1960/70: Some 6 cylinder Falcons/Fairlanes/Comets/Mustangs had 4 lug 13" wheels, 4 lug 14" wheels.
