White smoke when cold
Old Nov 22, 2008 | 09:33 PM
superduty4x4's Avatar
superduty4x4
I've noticed the past few mornings that when I start my truck in the AM it will chug a fair bit of white smoke for a few seconds. I thought it was kind of strange since my GP's were replaced with Motorcrafts around July sometime but didn't worry too much about it. Yesterday I started it up and was moving the car seats from the Exploder to my rig and noticed that even after idling a few minutes (long enough to let the high idle kick in) that it was still puffing a small amount of white smoke from both tail pipes. Not very much, but noticeable when you look close.
My question is, what could the problem be? I still need to put the DMM on the GPR and see what its doing. I know it works at least somewhat because the dash lights dim down and stay that way for about 2min on a cold start. What are other potential problems I should be looking at?
Early turd 99, stock injectors (no injector work as far as I know), stock GPR, EPBV unplugged, new glow plugs last July, no tuner, 01 PMT2 PCM, 6637 intake.
Old Nov 22, 2008 | 10:08 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Dude, it is on it's last legs, it is about to puke. Set it on fire and get an insurance claim.
Not really. Mine smokes like nobody's biz when cold. It is seriously annoying to me. Been that way ever since the new injectors. The jectors give great power, but cold start smokies are annoying as he!!. I would be bent out of shape except I saw the same thing in Swamps employee trucks when they first started theirs last winter. What can I say? If you find it out let me know.
I know, different situation but at least a bump to the top.
Old Nov 22, 2008 | 10:52 PM
zx250's Avatar
zx250
Of the next Riffraff East
Other than making sure your air intake heater is working (most of us don't have one anymore), there's not much you can do except wait until it warms up enough to burn up that white smoke.
Old Nov 23, 2008 | 11:22 AM
superduty4x4
After flipping through some nickel ads yesterday and seeing several 00-02 7.3 crew cabs for $10K and under I've considered it!
No AIH, mine's an early bird. If it's normal I'll stop worrying about it, but I didn't think these trucks were supposed to smoke that much when cold.
Old Nov 23, 2008 | 12:27 PM
zx250's Avatar
zx250
You could also check and make sure your EBPV is working.
Old Nov 24, 2008 | 09:19 AM
superduty4x4
EBPV is unplugged because last time I tried to drive with it plugged in, it would flap shut on decel. The EBPS tube was checked sometime last summer, not plugged up and no holes.
FWIW, after changing oil/filter and fuel filter yesterday I cycled the key a 4-5 to fill the fuel bowl back up. Just doing that pulled my batts down so low the truck wouldn't crank. 30 minutes with the jumpers hooked up and finally putting a portable jump starter on the other batt got it to barely fire, so I went to WalMart and bought 2 new batts yesterday.
Old Nov 24, 2008 | 09:48 AM
PwerStroke99's Avatar
PwerStroke99
Chase, that is perfectly normal, mine does that for a few seconds every morning here in Spokane. i deleted my AIH and it smokes like u described. If and when u drive it and it goes away, you are ok.
Old Nov 24, 2008 | 09:52 AM
superduty4x4
I'm glad its normal... gives me one less thing to have to fix!
Old Nov 24, 2008 | 11:59 AM
DieselBeast01's Avatar
DieselBeast01
Mine smokes like crazy in the early morning as well...it has done it since I bought it.
Old Nov 24, 2008 | 07:28 PM
big poppa's Avatar
big poppa
Mine smokes a little white smoke also when its cold outside, little more a less depending on how cold.
Old Nov 24, 2008 | 07:52 PM
Bigcat350's Avatar
Bigcat350
Since I put the swamps single shots in mine smokes like crazy when you first start it if its cold. But it runs great. But it still bugs me to see the white smoke.
I still have not got the program changed this could have some thing to do with it.
Old Nov 24, 2008 | 08:01 PM
c125bob's Avatar
c125bob
Yep, if it's in the low 30's or colder I get a some white smoke too. She starts up quick, might romp once, smokes a few seconds then clears up. I'm not gonna worry about it, she's old enough to smoke !
Old Nov 24, 2008 | 10:41 PM
superduty4x4
I keep forgetting to add- after letting the truck sit overnight I tested the GPR before turning the key on in the AM. With the key off I got 12.4v on one post of the GPR and nothing on the other side. Once the key was turned on, the voltage dropped to around 10.5v on both terminals. Should there be that much voltage drop when the glow plugs light off?
Old Nov 24, 2008 | 10:47 PM
PaysonPSD's Avatar
PaysonPSD
NO. Last time I checked there was less than 1/2 volt drop. I see some trouble shooting in your future.
Old Nov 24, 2008 | 11:45 PM
crum71's Avatar
crum71
1/8 mile Oval Track
I am glad to see the white smoke when its cold is normal, mine does it also
