engines locked up. is it fixable!!!! help
Old Nov 25, 2008 | 06:32 PM
  #31
MY_TRUCK_IS_BEAST's Avatar
MY_TRUCK_IS_BEAST
1. no
2. yes, and as stated on a earlier post, it moves but is very difficult to turn
3. no =\ would pulling it off and using a current meter work?
4. nope, but when this incident happened me and some friends banged on it with a tap hammer to try and unsieze it for the time being if it was the problem.
Old Nov 25, 2008 | 06:37 PM
  #32
danr1's Avatar
danr1
Originally Posted by 91f2504x4
I am confused on exactly what you have done here to diagnose the condition.
Please answer the following questions.
1. Has the engine ever actually turned over since the incident?
2. Have you tried turning the engine over with a socket and breaker bar on the crank bolt?
3. Have you checked to make sure current is getting to the starter, not just a bad solenoid?
4. Have you pulled the starter to make sure that it is just not trash, it could be locked or seized?
If you can turn the engine with a breaker bar fairly easy then it could just be a starter problem (go ahead and try this with the plugs out). If you can't turn it over with a breaker bar, then something is broke inside and it is time to pull the engine.
MY_TRUCK_IS_BEAST stated in post #28
<i>well anyways i pulled the plugs <b>and spun it a few times</b> not much really happened aside from some oil mixed with unknown fluids coming out.</i>
Well yea I see what you mean, I assumed he did that with the starter but I could be wrong.
Now that I reread this I think not,
<i>and yeah i can hear the fuel pump run but all it does is pop like when a battery still has charge but not enough to start,</i>
and this,
<i>also i put a screw driver on the two nuts on the solenoid and i get spark so i know its not the battery but my mind keeps coming to it because of the sound</i>
No, it doesn't sound like the motor turns over with the starter does it.
First time I read that as turns over but kinda weak, tries to fire but doesn't quite get it.
Old Nov 25, 2008 | 06:42 PM
  #33
91f2504x4's Avatar
91f2504x4
and this,
I read everything he had typed but it didn't really go into enough detail to let anyone know exactly what is going on , I was trying to get some good solid answers in one place to help people diagnose this for him.
Old Nov 25, 2008 | 06:49 PM
  #34
MY_TRUCK_IS_BEAST
its fine, all my friends say im not a very explanatory person...ask all the questions you need all i want is to get my play truck back lol
Old Nov 25, 2008 | 06:53 PM
  #35
91f2504x4's Avatar
91f2504x4
Originally Posted by MY_TRUCK_IS_BEAST
1. no
You can pull the starter off and take it to any autozone or advance auto parts or place like that and they will test it for you, for free.
A starter can bind badly enough that tapping it with a hammer won't help, especially if it was hot when it hit the water and the nose cracked on it, causing it to bind. I have had them crack before and the starter lock, even when they are brand new, sometimes it just happens.
If you can get the starter figured out then you can try diagnosing from there. It should be fairly easy to turn the engine over with a breaker bar on the crank with the plugs out, if it is difficult, you either have something bent or some heavy rust in the cylinders, but I wouldn't think that would have occured so quickly. You can try taking an oil can and dropping a bit of oil down in the cylinder (through the plugs holes) and turning it over with a wrench for a bit and see if it smoothes out. But it may be too late for that, if you can get it to where your starter works and it turns over smoothly, then you can do a combustion test and see if it is within reason.
Old Nov 25, 2008 | 07:00 PM
  #36
MY_TRUCK_IS_BEAST
ok thanks, and all the stuff i know about rust theres no way that could have occurred in 4 days. but thinking on it if the crank turns and the starter is good, wouldnt you be able to hear the starter trying to turn it over, just an assumption
Old Nov 25, 2008 | 07:21 PM
  #37
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
It could be that the starter is just not engaging the flywheel.....
Also might want to check the distributor to make sure water aint in there.....
Old Nov 25, 2008 | 07:25 PM
  #38
MY_TRUCK_IS_BEAST
i checked the distributor there was nothing in there, but it looked like some residue from dirty creek water is in there but there is NO water in there now..
Old Nov 25, 2008 | 07:40 PM
  #39
05chop's Avatar
05chop
What came out of the oil pan when you drained the oil out?
Old Nov 25, 2008 | 07:48 PM
  #40
MY_TRUCK_IS_BEAST
so i just got in from work, went straight to my garage and attempted to the crank and turned pretty easily that made me kind of excited. then my hopes got back down i drained all my oil out into our pan while my dad was behind me he looked at the oil and said it was filled with water and it was a milky chocolate color. so should i change my oil and try to start it, with all this any suggestions would be fine. the crank did turn but was pretty hard to turn.
it was a milk chocolate color and was mixed with maybe a 1/4 quart of water, and barely any came out of the cylinders when i spun it so im assuming it all drained down into the oil pan after 4 days.
Old Nov 25, 2008 | 08:02 PM
  #41
05chop's Avatar
05chop
Is the radiator full of water?
Old Nov 25, 2008 | 08:04 PM
  #42
MY_TRUCK_IS_BEAST
yeah, just wondering but how will that effect it starting at all?
Old Nov 25, 2008 | 08:05 PM
  #43
MY_TRUCK_IS_BEAST
well by yeah i meant it has the perfect water/antifreeze mixture not creek water
Old Nov 25, 2008 | 08:19 PM
  #44
05chop's Avatar
05chop
Well the brown oil concerns me! Are you thinking the creek water entered the engine? If so where did it go in at? This all goes back to basic knowledge of what makes an engine work. air,fuel,spark,compression, oh a good starter too and battery.
Old Nov 25, 2008 | 08:39 PM
  #45
alz's Avatar
alz
He originally said his K&N filter was soaked. So maybe we can assume it did injest some water, just not sure of the amount or damage it may have caused.
