Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
No idle when cold
Old Nov 21, 2008 | 04:10 PM
nairod's Avatar
nairod
No idle when cold
This is my first Escape post - mostly I have questions on my 76 F150.
I have a 2003 6 cyl Escape with 120,000 miles. Yesterday it began to not idle when cold.
It will start but will die instantly if I don't work the throttle. It will run and drive but I had to power brake it at stops. I drove it about 15 miles and it seemed to be willing to idle at that point. The engine was completely warmed up.
This morning it repeated the problem.
I'm in Kentucky and the temps are in the 20s and 30s.
I guess there is a cold start sensor or equivalent? Can a regular guy test it and/or change it?
Thanks!
Old Nov 21, 2008 | 06:07 PM
wptski's Avatar
wptski
I just sold a 97 Ranger to get a 09 Escape. Not exactly sure how the newer ones operate similiar to the 97. Idle is controlled by the PCM from inputs from sensors like the TPS, MAF, coolant temp, air temp and maybe more. The PCM sends a pulse modualted signal to the IAC(idle air control) valve which bypasses the throttle plate to increase/decrease air to the engine.
You need some good books and a good OBD-II scanner capable of monitoring engine parameters. A scanner can tell you by just turning the key to ON at what values your sensors are.
Temperature sensors can be checked with a ohm meter and a chart to tell you what they should read at what temperature. They have charts like that in the Ford manuals I had for my 97 Ranger.
Old Nov 22, 2008 | 04:01 PM
nairod's Avatar
nairod
Thanks, wptski.
I don't think I want to tackle it, then. You're right in suggesting doing a proper diagnostic check, and I'm not the guy to do it.
I'm not a big fan of the local Ford dealership, but I guess I gotta bite the bullet.
Old Nov 23, 2008 | 03:36 PM
aj7885's Avatar
aj7885
idle problem
sounds like the idle air control valve. Very common on mid 90's early 20's Ford engines. Search this forum for some xlent advice on replacing it.
Old Nov 23, 2008 | 10:49 PM
wptski's Avatar
wptski
If it was the IAC itself, you probably get a CEL/SEL. It's only two screws and a connector but it'll cost you $100 to guess at it. It's pulse modulated operated so you just can't put 12V across it to test it.
My AutoXray scanner doesn't cover 09 yet but it worked on my Escape but only showed 37 PIDs but not a IAC. A 07 Ford Taurus shows 90 PIDs.
Old Nov 24, 2008 | 09:17 PM
aj7885's Avatar
aj7885
I have had 3 idle air controls go bad, 98 V6 F150, 96 302 F150, 01 V6 escape. None of them caused a check engine code to appear. They all would not cold start but you could usually get them to run by stepping on accelerator till engine warmed up. Textbook symptom, $65.00- $78.00 for new unit. Cleaning can help in short term but they usually end up needing replaced.
Old Nov 24, 2008 | 10:38 PM
wptski's Avatar
wptski
Don't you find that odd that you've replaced so many IACs? I do! Do you know anybody else that has replaced as many as you? If cleaning helps this sounds like you have a unique dirty air problem. I have heard of the port from the IAC to the post-throttle port plugging up.
I've never replaced the one on my 97 Ranger 4.0L.
As far as the CEL goes, normally it takes three pending codes to generate a CEL. Once driven they would clear themselves.
You haven't played with the throttle return control screw?
Old Nov 25, 2008 | 06:26 PM
aj7885's Avatar
aj7885
do a search of this forum, will find many bad idle air control valves, Ford had a big problem up until about 2003/04. I think they got the problem corrected. My wifes 05 Duratec V6 doesn't use idle air any more. I think Ford uses MAF and other controls for idle control now.
Old Nov 25, 2008 | 06:49 PM
wptski's Avatar
wptski
My 97 Ranger was a MAF system. The scan of my 09 Escape shows a MAP, so there's no MAF used.
Old Nov 25, 2008 | 10:37 PM
wptski's Avatar
wptski
I did the search for IAC. Yes, lots of posts but many just want to clean theirs just for the sake of cleaning them. Some pull the connector and the idle doesn't change or engine doesn't die, so they have other problems. I got bored reading them after a while.
Old Nov 26, 2008 | 08:33 PM
nairod's Avatar
nairod
Well, the latest:
For the last 3 days, I have been able to get it to idle by starting it, blipping the throttle for a few seconds, and then it settles down to a normal idle. It still would die on the initial start if I didn't rev it until it stabilizes.
So it continues to exhibit the symptoms, but they are milder.
Since I have no diagnostic tools and most folks seem to say there is no code generated anyway, I guess I will rummage around under the hood and see if I can clean it and have the problem go away.
If it does, then I will know how to replace it with a new one when it reoccurs.
If it doesn't go away, then I guess it's a trip to the Ford dealer. Yuk.
Old Dec 10, 2008 | 06:35 PM
bluestang65's Avatar
bluestang65
The design of the Ford IAC is aweful. Frankly, it is unlike everyone elses in the industry and more prone to failure. It gets gummed up and never works quite right after that. The only correction I have seen is the use of drive-by-wire systems. Those systems do not use an IAC generally because the throttle plate can be opened without input from the driver. They know it sucks. In the early'90s they would put a spacer between the IAC and throttle body that allowed outside air in metered by a screw.
Old Dec 26, 2008 | 08:57 PM
bmuhlbach's Avatar
bmuhlbach
When mine went haywire it did not turn the check engine light on.Also mine didn't do it all the time.
Old Dec 27, 2008 | 07:15 PM
aj7885's Avatar
aj7885
no idle
Thanks for the posts. Please let the forum know the outcome and fix required. Thanks
Old Dec 28, 2008 | 05:21 AM
MFJ's Avatar
MFJ
Might also be time to check some of the basics. How are your vacuum lines? After a while they do break down and leak, and can cause similar problems. I recently replaced the vacuum lines on my '96 Sable (Duratec engine) and the improvement was great. It now starts and idles in the winter, without feathering the gas pedal to get it to run.
