2005 bed extender question
Old Nov 21, 2008 | 12:47 PM
bigwin56f100's Avatar
bigwin56f100
I dont have one , but was thinking about getting one. My question is instead of being an extender on the gate, can it be flipped around and be used as a cargo holder? If so will it fit under my bed cover?Thanks,Kevin Bigwin
Old Nov 21, 2008 | 02:55 PM
vtx1800's Avatar
vtx1800
That's how mine works on my 2007 and it fits under the tonneau
Old Nov 21, 2008 | 03:20 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
yes to both questions.
the OEM one is designed to fit beneath the bed rails when inside the bed
Old Nov 24, 2008 | 02:57 AM
Shmuck's Avatar
Shmuck
Any idea how much they cost approximately??
Only problem i can see in my situation, is with a bed extender installed, are they easily removed?? I have a dirt bike that I need to load on and off the truck.
Old Nov 24, 2008 | 06:05 AM
4x4xCrew's Avatar
4x4xCrew
If you get one from an '08-up it will split and fold together to store against each side of the bed.
Old Nov 24, 2008 | 07:45 AM
vtx1800's Avatar
vtx1800
Not sure about the cost new, mine is second hand, used but it pops in an out in 30 secs.
Its great for keeping the groceries in place and tying on the bbq propane tanks when I need to refill
Old Nov 24, 2008 | 08:51 AM
BrianFX4's Avatar
BrianFX4
I just bought an OEM one off Craigslist for $60 then went to a dealership and bought the bolts that you scred into the side of your bed for $22 and some change. It pops off and on in seconds.
If you by the whole setup new from Ford it will run you $400+ to get it. I know because I called before I looked on Craigslist.
Old Nov 24, 2008 | 12:54 PM
Shmuck's Avatar
Shmuck
Wow, under $100 from Craiglists, thats a good deal. They are $189ish on Ebay.
If any of you have ever driven over a rough road with the tailgate down, you'll know that you can pop the tailgate off its hinges. Is the bed extender designed to prevent this from happening, or does it just rest on the tailgate, not putting enough pressure on the tailgate to prevent it from 'bouncing'? If not, then do you think that the hinges on the bed extender are strong enough to handle a bouncing tailgate?
With my dirt bike in the back, the back wheel only just sits over the tailgate. So that wont put enough weight on the tailgate to prevent it from bouncing either. Point is that when I head out to the desert, we go over some rough patches off road. Dont want to whole thing coming apart on me!!
Old Nov 24, 2008 | 03:24 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
it will also do it when you have something in the bed that pushes on the bottom of the tailgate as you close the tailgate...pops right off.
an easy cheap fix for ya though.
get a big zip tie, or a big hose clamp. on the passenger side of the tailgate hinge, just wrap it with the zip tie or the hose clamp.
^^^ will prevent the tailgate from coming off accidently. the zip tie/clamp prevents it from slipping out the groove
Old Nov 25, 2008 | 02:47 PM
65steelstallion's Avatar
65steelstallion
my bed extender did not fit with the "extang tonneau" cover rails. i sold it. i had the same problem with my 04 xlt, presently have 06 king ranch
Old Dec 8, 2008 | 10:13 AM
rcaddell's Avatar
rcaddell
Bed Extender will not work with all tonneau covers. Check with the cover manufacturer to see if it will.
I picked mine up on ebay, 90 bucks. Came out of an 08 and does not split and fold together.
Old Dec 12, 2008 | 04:13 PM
evilwayz7's Avatar
evilwayz7
If I was you I would just put a ratchet strap from the bed extender, if you get one, to your hitch receiver to hold the tailgate down snug. This should keep it from bouncing around a lot. I also got a bed extender for $40 with the brackets and bolts on craigslist. It lifts off in about 2 seconds so I can load my quad then put it back on to use your tailgate as more storage space.
bigwin56f100
Mar 30, 2011 10:12 AM
bigwin56f100
1966 - 1977 Early Broncos
16
Feb 27, 2010 09:33 AM
bigwin56f100
May 19, 2009 04:46 PM
bigwin56f100
Ohio Chapter
Nov 27, 2008 08:35 PM
bigwin56f100
Oct 13, 2003 10:47 PM
