How do you know if a 66 289 is a HI PO or not? - Ford Truck Enthusiasts Forums
Old 05-16-2009, 05:35 PM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is online now
bigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant future
Hello,
I am out of my normal domain on this small block. I just picked up a C5 block, C8 4V intake and 66 heads that say 289 with angle plugs.
My question is how to identify a HI PO 289, is mine ?
Thanks,
Kevin Bigwin
Old 05-16-2009, 09:58 PM
Beechkid
Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
The A, C, D code engines have hydraulic lifters & vacume distributors. The K codes have solid lifters & duel point mechanical distributors.
Old 05-16-2009, 10:11 PM
johnboy427's Avatar
johnboy427
johnboy427 is offline
johnboy427 is starting off with a positive reputation.
There should be a counter weight between the dampner and the crank sprocket if it is indeed a real K motor.
-Johnboy
Old 05-17-2009, 12:38 AM
93F22A6
93F22A6 is offline
93F22A6 is starting off with a positive reputation.
Also on the HIPO heads, they had screw in rocker studs. The others had pressed in studs like my 289 heads on my 302.
Old 05-18-2009, 05:30 PM
gearhed1971's Avatar
gearhed1971
gearhed1971 is offline
gearhed1971 is starting off with a positive reputation.
Also beefier main caps
Old 05-18-2009, 06:11 PM
85e150six4mtod
85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
And 3/8s rod bolts in most cases....
Old 05-19-2009, 11:52 AM
bigwin56f100
Thanks for the replies, Its NOT a HI PO. Oh well !
Thanks Kevin Bigwin
Old 05-19-2009, 03:05 PM
85e150six4mtod
Still a good engine with lots of potential. 200, 250, 300 or more hp depending on your budget. Note the Hi-po motors were gross rated at 271 hp, so net they were probably 230 or so net.
Old 05-19-2009, 05:46 PM
gearhed1971
I like mine
shameless
03-14-2009 05:28 PM
60F100
01-04-2009 01:58 PM
imlowr2
Engine Swaps
12-12-2007 12:31 AM
cwpowell
03-21-2007 08:40 PM
roger dowty
05-07-2006 03:52 AM
Quick Reply: How do you know if a 66 289 is a HI PO or not?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
