no power
Old Nov 21, 2008 | 09:04 AM
rupejosh's Avatar
rupejosh
Exclamation no power
it is one thing after another.this morning went tou to the truck to fire it up and head to work it was turning over then all the sudden i lost all electrical the headlights or nothing will come on i tested the batteries and they are good.is there a master fuse somewhere?what would cause this?
Old Nov 21, 2008 | 09:07 AM
fuzzy1626's Avatar
fuzzy1626
All the battery connections clean and tight?
Old Nov 21, 2008 | 09:09 AM
rupejosh's Avatar
rupejosh
i just replaced all the connections and they are all tight.first thing i checked
Old Nov 21, 2008 | 09:13 AM
rupejosh's Avatar
rupejosh
could the starter solenoid cause this?
Old Nov 21, 2008 | 09:27 AM
fuzzy1626's Avatar
fuzzy1626
I think there are some fuseable links in the system, but I can't help you with location. Sorry.
Old Nov 21, 2008 | 10:20 AM
rupejosh's Avatar
rupejosh
had a bad wire and my pos.terminal on the pass. side was shot
Old Nov 21, 2008 | 10:43 AM
AndysFords's Avatar
AndysFords
Probably the wire between the starter solenoid and the alternator, right? Mine did the same thing just a few weeks ago and the wire was burnt up.
Old Nov 21, 2008 | 08:04 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The passenger side positive battery terminal is probably responsible for 60+% of the electrical problems in these trucks.
Old Nov 22, 2008 | 12:45 AM
rupejosh's Avatar
rupejosh
i think im going to look for some big beefy terminals and replace them all again so i can prevent this issue again i would rather spend and extra $30 than be stranded and have a nasty tow bill.thats my thinking anyway
Old Nov 22, 2008 | 04:03 AM
LCAM-01XA's Avatar
LCAM-01XA
Some of these trucks have a pretty stupid electrical wiring - mine for instance had the charge wire from the alternator going to the battery like it should, but the power feed from the battery to the rest of the truck was not coming from the battery terminal to the fender-mount starter relay, but instead was coming all the way down from the starter, in other words the current would travel all the way down through the fat starter cable, then travel back all the way up to the starter solenoid. It looked like a factory setup too, and I've seen it on at least two junkyard trucks. Trace your power feed to the fender-mount starter relay, you may have the odd setup like me...
Old Nov 22, 2008 | 06:51 PM
fuzzy1626's Avatar
fuzzy1626
Glad to hear you found the problem.
Old Nov 22, 2008 | 11:37 PM
AndysFords's Avatar
AndysFords
Never seen anything like that, I have two 83 trucks, one 84, two 86, and one 88. All of them have the hot wire going from the battery across to the starter solenoid, then down to the glow plug solenoid(not the 88) and then to the alternator, but between the GP solenoid and the alternator it splits off like 3 or 4 times, goes all different places I guess, but that wire from the GPs to the Alternator is 50% of my problems it seems lately.
jhaas63
Sep 30, 2012 10:33 PM
glruff
Delaware Chapter
435
May 12, 2008 04:33 AM
Nachoman
New Member Introductions
Nov 26, 2006 06:24 AM
rockfordboy
39
Feb 28, 2003 06:51 AM
fordtruckin
Mar 10, 2002 10:50 AM
