leaking rear end
Old Nov 21, 2008 | 10:45 PM
mueckster's Avatar
mueckster
I do not gauge the torque of the nut, as with any differential with a crush collar. I check for the preload or "drag" felt when turning the yoke. I move it just enough to feel the backlash and not turn the ring gear. You can read the preload on the bearings with an inch-pound torque wrench while turning the pinion and adjusting it to specs for new or used bearings. I do use a torque wrench. I have used the "feel method " for 28 yrs in the auto, offroad, and OTR truck mechanic field.
Old Nov 21, 2008 | 11:06 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke
I see so it really is more of a feel method. Well I thought about replacing the seal again but I had no idea where to retorque the nut too. Guess I will just have to have somebody that has the correct "hand" do it.
Old Nov 21, 2008 | 11:19 PM
mueckster's Avatar
mueckster
Wish I could lend you mine LOL, but I'm alittle too far away. Good luck in getting that leak fixed. Don't let it go.
Jolly Roger Joe
Sep 18, 2016 11:07 AM
little_mule
Nov 4, 2009 07:33 PM
xlt4wd90
Aerostar
69
Jun 28, 2006 07:05 AM
phoneman
Mar 21, 2004 06:53 AM
