Help !!!/SC
Old Nov 20, 2008 | 11:15 AM
rb9192's Avatar
rb9192
Question Help !!!/SC
I have a 2001 Ford Escape, V6. It sputters and sometimes cuts off when I first crank if up in the morning, then it also does this when I crank if up at lunch. It has 132,000 miles. What could be causing this?
Thanks !
Old Nov 20, 2008 | 12:41 PM
Fomoko1's Avatar
Fomoko1
Hi, sorry to hear about the Escape problem, post this in the Escape and Escape Hybrid forum: https://www.ford-trucks.com/forums/forum36/
Also be sure to drop into your local SC chapter: https://www.ford-trucks.com/forums/forum183/
Old Nov 20, 2008 | 01:39 PM
rb9192's Avatar
rb9192
Thanks for the info. I can't seem to get it to post for some reason.
Old Nov 21, 2008 | 01:28 AM
Fomoko1's Avatar
Fomoko1
Do you have an idea of what the problem is, what happens when your try posting?
Old Nov 21, 2008 | 08:28 AM
rb9192's Avatar
rb9192
It gives me the below message. And I'm doing a search, trying to post !
This forum requires that you wait 60 seconds between searches. Please try again in 50 seconds.
<!-- / main error message -->
Old Nov 21, 2008 | 06:34 PM
glruff's Avatar
glruff
FTE Leadership Emeritus
Hi rb9192, welcome to FTE!
The issue you are having with posting or searching is built into the database software. You must wait 60 seconds between posting new a message and also wait that length of time between submitting a new search.
There is nothing you are doing wrong and nothing wrong with your computer.
Gilmera7500
New Member Introductions
Aug 13, 2018 09:07 AM
mexicancan
Jun 29, 2013 07:09 PM
expo50
Mar 21, 2008 04:18 PM
enfield_chris
May 13, 2007 11:39 AM
