warming trans in cold weather
Old Nov 20, 2008 | 10:24 AM
tobra's Avatar
tobra
4wd Low
77 C6 trans, when cold won't engage. What s the best way to warm the trans in cold weather(-15). 1-trans in park, 2-trans in neutral, 3-trans in gear. And if you could tell me why that way.
Thanks
Old Nov 20, 2008 | 12:23 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Park and neutral are the same. In gear is the way to warm up the trans. When it is in gear the output of the torque converter is held while the input is turning with the engine. This shears the ATF, which is where most of the heat in a trans comes from.
Old Nov 20, 2008 | 02:51 PM
rclarke's Avatar
rclarke
A C6 with delayed or no drive cold is probably due for an overhaul. Usually this is caused by hardened seals in the forward clutch.
reamer
Escape & Escape Hybrid
20
Mar 13, 2017 04:36 PM
Kert0307
Jan 20, 2011 01:49 PM
09 Razor
2009 - 2014 F150
19
Dec 23, 2009 09:36 PM
60man
17
Jul 21, 2007 12:25 AM
wthayer1
Oct 24, 2006 04:37 PM
