Camper Special rear axle
<table id="post9020031" class="tborder" width="100%" align="center" border="0" cellpadding="6" cellspacing="0"><tbody><tr valign="top"><td class="alt1" id="td_post_9020031" style="border-right: 1px solid rgb(204, 204, 204);"> I'm talking to guy about a rear 60 to match my front 79 hp 60 which is a little over 69". He told me his rear 60 is from a SRW 78 f250 camper special and that the width is 63.75". That sounds pretty narrow to me. He also says it's FF but the drums are behind the hubs, not slide on. I'm a little in the dark about this as well. Any Idea what axle he may actually have? Is this a dually axle?
<!-- / message --> </td> </tr> <tr> <td class="alt2" style="border-style: none solid solid; border-color: -moz-use-text-color rgb(204, 204, 204) rgb(204, 204, 204); border-width: 0px 1px 1px;"> </td> <td class="alt1" style="border-style: none solid solid none; border-color: -moz-use-text-color rgb(204, 204, 204) rgb(204, 204, 204) -moz-use-text-color; border-width: 0px 1px 1px 0px;" align="right"> <!-- controls --> </td></tr></tbody></table>
Full floater axle's seldom have slide on drums, in fact, they never did. It was not until the Sterling 10.25 axle that the wheel lugs did not press the hub and drum together.
The dana axle will have to have the axle removed, as well as the hub removed from the spindle to remove the drum.
Also, why the desire for a matching rear Dana 60 anyway? The dana rear has rather weak shafts, and unless they are upgraded, are not as strong as the 60 front.
Thanks I realized what your talking about ( drums)after I went outside and looked at the 70 sitting in my back yard. I was thinking the drum slid over the hub.
I'm putting these axles in a Jeep running a 4.0l and probably 38.5" tires. I'll bore out the spindles and upgrade the shafts to 35 spline alloys while I'm building it. I would think twice if this was going into a full size truck but my junk weighs around 4400 lbs.
Cutting the spindles and re-welding them in requires a large boring bar and a stout set up to keep everything straight. Obviously can be done though. Heak for 80 bucks, having them bored is a decent solution. I run mine in a fill size, and it is loaded pretty heavy quite often, and sees its share of reasonable speed air time. I have not had a problem with bored spindles, but I cant seem to keep stock D70 shafts in it.
A lighter vehicle could very well hold up to this modification.
Thanks for the info on the spindles. I'll definitely have them bored. Should be a pretty stout set up for a Jeep, especially that front 60 with 35 spline outers. Been looking for one for a while reasonably priced and finally picked one up for $500. I see them quite a bit for $1000-$1400 but no way I was going there.
paulem
12-12-2014 02:29 PM
