<b>remove dash panel
Old Nov 18, 2008 | 06:14 PM
spookypooky's Avatar
spookypooky
Question <b>remove dash panel
i have the panel off to get to the radio and ac/heat controller, but the lights and wipers are the only things hindering me from completely removing the panel, is there a way to get this off? or do you just have to have it there as a nuisance.
Old Nov 18, 2008 | 06:39 PM
75F350's Avatar
75F350
You have to pull pretty hard on the **** for the windshield wipers, and the headlight has a botton that has to be depressed to release the entire shaft from the switch. You will have to reach behind the dash and feel for the back side of the entire switch for a small button. Depress it while you pull the **** and you will end up with the entire shaft in your hand. Once all the screws for the surround have been removed, you can take everything apart.
Lots of luck.
Old Nov 18, 2008 | 08:18 PM
Alvin in AZ's Avatar
Alvin in AZ
"Aaaaaaaaaa 8-() " -Beavis
75's got the headlight switch part right, the whole **** and shaft come out
after you hold down on the button at the back-top of the switch housing. :)
The windshield wiper **** comes off the shaft real nice and easy if you pull
the tab (spring sheet steel) that's wedging/pinching the shaft. :)
Alvin finally knowed sumthin' in AZ?
Old Nov 18, 2008 | 09:54 PM
spookypooky
thanks ill give that a try, i was kinda worried about pulling too hard in fear of breaking something, but the ***** shouldnt be too hard to replace
Old Nov 18, 2008 | 10:26 PM
spookypooky
that definatley worked! thanks guys.
Old Nov 18, 2008 | 11:01 PM
Tees77f150's Avatar
Tees77f150
I'll have to try that. One of my winter projects is to take the original AM radio out and put in a period correct AM/FM and replace the broken off antana.
Old Nov 19, 2008 | 10:33 AM
spookypooky
im just trying to find a radio. and rewire the speakers. get boring with just me in the truck and no other sounds
Old Nov 19, 2008 | 10:53 AM
Rockstone's Avatar
Rockstone
Sounds to me like you need headers and cherry bombs.
Old Nov 19, 2008 | 11:05 AM
Alvin in AZ
Yep! :)
http://www.panix.com/~alvinj/file12/gearshift.jpg
Alvin in AZ
Kuvasz1
Dec 31, 2011 10:26 AM
ZFamly
Jan 29, 2011 11:20 AM
79FordBlake
Dec 5, 2010 06:54 PM
reamer
1997 - 2003 F150
Jan 27, 2007 01:08 PM
yechave
Appearance & Dress-Up
Feb 24, 2006 11:08 AM
