firing order question
Old Nov 19, 2008 | 09:21 AM
jonwoos's Avatar
jonwoos
Originally Posted by jonwoos
93 and under truck, cars 5.0l use the 15426378
94 up 5.0l truck, mustang HO, and 5.8 use 13726548
if I remember correctly
Fixed orders, and dates, tried to do it in above post, but it would not let me.
Old Nov 19, 2008 | 10:29 AM
quicklook2's Avatar
quicklook2
sounds like a "frankentruck".
it's alive!
little bit of this and a little bit of that.
Old Nov 19, 2008 | 11:14 AM
jonwoos's Avatar
jonwoos
it's alive!
True, the engine was suppose to be a 60K mile Mustang 5.0L, and a fresh rebuilt AOD. They had vacuum line messd up everywhere, EGR blocked off with wires hanging, no smog stuff, no fan shroud, and a flex fan. Plus leaking exhaust, and loose oil pan. Wrong oil pressure sending unit, gauge operated backwards. I got it for $900, the body, and frame have NO rust, a few dents here, and there. It is a 4x4 with 3:55 gears and manual lock outs. It is a XLT Laroit truck, so it was decked out. I does run good, but I was just checking some more stuff out, and straightening up things on it.
Old Jul 20, 2021 | 08:41 PM
96greenie's Avatar
96greenie
Yeah, I was told it was an HO motor, but it wired as a regular 5.0L. I was mainly checking to make sure.
But, would you have to re-time it after the wiring change to make sure? Or, is the timing corect no matter what?
Ur pulse signal won't jive.not like old style point dizzy
Old Jul 22, 2021 | 01:56 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Last activity from the OP was 7/21/2016 and the last post this thread is from Nov 2008.
makingaZJ
Jul 20, 2021 08:43 PM
truckfarmingcanuck
Mar 1, 2009 12:10 PM
blindboyth
17
Oct 23, 2008 09:00 AM
BrianLXcpe
Jul 10, 2002 04:37 PM
saxtonj
Nov 3, 2001 10:18 PM
