Blower is Crazy
Old Nov 18, 2008 | 01:00 PM
MRB1752's Avatar
MRB1752
Blower is Crazy
The blower in my 03 Mountaineer is crazy. If I have it set on the lowest setting it will sparatically blow out a full blast. Sometimes it will stay that way for a split second other times for for ten minutes. Then it will go back to low for a few seconds the back to full. Over and over and over. It has been doing this for about 2 years now. Getting worse over time. Now my wife drives the car. So I am sure you can see why I need to get it fixed.
I have searched the forums and the only thing I see is the blower motor resistor but that usually makes it blow full all them time.
Old Nov 19, 2008 | 01:45 PM
rrgone's Avatar
rrgone
If yours has Dual Automatic Temp Control (DATC) there is no blower motor resistor. Instead it will have a Blower Motor Speed Control module. It's a good bet that's what the culprit is. I'm pretty sure the part number is XL2Z-19E624AA, and I see it can be had for $55.66 from directfordparts.com. Make sure to double check that part number before you order. You might even get one from a salvage yard for cheap. I have no idea what a regular dealer would want for one. Good luck.
Old Nov 19, 2008 | 01:47 PM
MRB1752's Avatar
MRB1752
Thanks for the help I will give that a try.
Old Nov 19, 2008 | 02:16 PM
rrgone's Avatar
rrgone
You're welcome. Post back up how it turns out.
RobVila
23
Aug 1, 2020 11:03 AM
Nicmike
Nov 26, 2019 09:46 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Nov 23, 2015 07:54 AM
zerocoolsob
13
Nov 30, 2014 10:08 AM
Polkster
Sep 6, 2014 09:39 PM
